Automation fired multiple times for unknown reason
I am using RPi3 and Latest HASS
In my automation, the switch triggers a simple bash script that send signals to activate an RF power switch
Here’s my switch config
switch:
  platform: command_switch
  switches:
    Lampu Ruang Tamu:
      oncmd: "sudo /var/opt/homeassistant/rfoutlet/RF1ON.sh"
      offcmd: "sudo /var/opt/homeassistant/rfoutlet/RF1OFF.sh"
Here’s my automation
- alias: 'RULE 2 - Turn on light when sun sets'
    platform: sun
    event: sunset
    offset: "-00:15:00"
    service: switch.turn_on
    entity_id: switch.lampu_ruang_tamu
- alias: 'RULE 2 Living Room Light OFF at 23:00pm'
    - platform: time
      hours: 11
      minutes: 55
    service: switch.turn_off
Now the funny thing here is, when I use the switch individually without automation, it fired once.
16-04-21 13:46:01 homeassistant.core: Bus:Handling <Event call_service[L]: service=turn_on, domain=homeassistant, service_call_id=1979121168-63, service_data=entity_id=switch.lampu_ruang_tamu>
16-04-21 13:46:01 homeassistant.core: Bus:Handling <Event call_service[L]: service=turn_on, domain=switch, service_call_id=1979121168-64, service_data=entity_id=['switch.lampu_ruang_tamu']>
16-04-21 13:46:01 homeassistant.components.switch.command_switch: Running command: sudo /var/opt/homeassistant/rfoutlet/RF1ON.sh
16-04-21 13:46:01 homeassistant.core: Bus:Handling <Event state_changed[L]: new_state=<state switch.lampu_ruang_tamu=on; friendly_name=Lampu Ruang Tamu @ 13:46:01 21-04-2016>, entity_id=switch.lampu_ruang_tamu, old_state=<state switch.lampu_ruang_tamu=off; friendly_name=Lampu Ruang Tamu @ 11:55:00 21-04-2016>>
16-04-21 13:46:01 homeassistant.core: Bus:Handling <Event service_executed[L]: service_call_id=1979121168-64>
But when put in automation, it fired multiple times.
16-04-21 11:55:00 homeassistant.components.automation: Executing RULE 2 Living Room Light OFF at 23:00pm
16-04-21 11:55:00 homeassistant.components.device_tracker.ddwrt: Checking ARP
16-04-21 11:55:00 homeassistant.core: Bus:Handling <Event logbook_entry[L]: domain=automation, message=has been triggered, name=RULE 2 Living Room Light OFF at 23:00pm>
16-04-21 11:55:00 urllib3.connectionpool: Starting new HTTP connection (1): 10.0.0.1
16-04-21 11:55:00 homeassistant.core: Bus:Handling <Event call_service[L]: service=turn_off, domain=switch, service_call_id=1979121168-3, service_data=entity_id=['switch.lampu_ruang_tamu']>
16-04-21 11:55:00 homeassistant.components.switch.command_switch: Running command: sudo /var/opt/homeassistant/rfoutlet/RF1OFF.sh
16-04-21 11:55:00 homeassistant.core: Bus:Handling <Event state_changed[L]: new_state=<state switch.lampu_ruang_tamu=off; friendly_name=Lampu Ruang Tamu @ 11:55:00 21-04-2016>, entity_id=switch.lampu_ruang_tamu, old_state=<state switch.lampu_ruang_tamu=on; friendly_name=Lampu Ruang Tamu @ 11:54:13 21-04-2016>>
16-04-21 11:55:00 homeassistant.core: Bus:Handling <Event service_executed[L]: service_call_id=1979121168-3>
16-04-21 11:55:00 homeassistant.core: Bus:Handling <Event state_changed[L]: new_state=<state group.all_switches=off; order=0, auto=True, entity_id=('switch.vaporiser', 'switch.lampu_ruang_tamu', 'switch.debuan_server', 'switch.lampu_malam', 'switch.plex_server'), hidden=True, friendly_name=all switches @ 11:55:00 21-04-2016>, entity_id=group.all_switches, old_state=<state group.all_switches=on; order=0, auto=True, entity_id=('switch.vaporiser', 'switch.lampu_ruang_tamu', 'switch.debuan_server', 'switch.lampu_malam', 'switch.plex_server'), hidden=True, friendly_name=all switches @ 11:54:13 21-04-2016>>
16-04-21 11:55:00 homeassistant.core: Bus:Handling <Event state_changed[L]: new_state=<state group.lampu=off; order=2, entity_id=('switch.lampu_ruang_tamu', 'switch.lampu_malam'), friendly_name=lampu @ 11:55:00 21-04-2016>, entity_id=group.lampu, old_state=<state group.lampu=on; order=2, entity_id=('switch.lampu_ruang_tamu', 'switch.lampu_malam'), friendly_name=lampu @ 11:54:13 21-04-2016>>
16-04-21 11:55:01 homeassistant.components.automation: Executing RULE 2 Living Room Light OFF at 23:00pm
16-04-21 11:55:01 homeassistant.core: Bus:Handling <Event logbook_entry[L]: domain=automation, message=has been triggered, name=RULE 2 Living Room Light OFF at 23:00pm>
16-04-21 11:55:01 homeassistant.core: Bus:Handling <Event call_service[L]: service=turn_off, domain=switch, service_call_id=1979121168-4, service_data=entity_id=['switch.lampu_ruang_tamu']>
16-04-21 11:55:01 homeassistant.components.switch.command_switch: Running command: sudo /var/opt/homeassistant/rfoutlet/RF1OFF.sh
16-04-21 11:55:02 homeassistant.core: Bus:Handling <Event service_executed[L]: service_call_id=1979121168-4>
16-04-21 11:55:02 homeassistant.components.automation: Executing RULE 2 Living Room Light OFF at 23:00pm
16-04-21 11:55:02 homeassistant.core: Bus:Handling <Event logbook_entry[L]: domain=automation, message=has been triggered, name=RULE 2 Living Room Light OFF at 23:00pm>
16-04-21 11:55:02 homeassistant.core: Bus:Handling <Event call_service[L]: service=turn_off, domain=switch, service_call_id=1979121168-5, service_data=entity_id=['switch.lampu_ruang_tamu']>
16-04-21 11:55:02 homeassistant.components.switch.command_switch: Running command: sudo /var/opt/homeassistant/rfoutlet/RF1OFF.sh
16-04-21 11:55:03 homeassistant.core: Bus:Handling <Event service_executed[L]: service_call_id=1979121168-5>
16-04-21 11:55:03 homeassistant.components.automation: Executing RULE 2 Living Room Light OFF at 23:00pm
16-04-21 11:55:03 homeassistant.core: Bus:Handling <Event logbook_entry[L]: domain=automation, message=has been triggered, name=RULE 2 Living Room Light OFF at 23:00pm>
16-04-21 11:55:03 homeassistant.core: Bus:Handling <Event call_service[L]: service=turn_off, domain=switch, service_call_id=1979121168-6, service_data=entity_id=['switch.lampu_ruang_tamu']>
16-04-21 11:55:03 homeassistant.components.switch.command_switch: Running command: sudo /var/opt/homeassistant/rfoutlet/RF1OFF.sh
16-04-21 11:55:03 homeassistant.core: Bus:Handling <Event service_executed[L]: service_call_id=1979121168-6>
16-04-21 11:55:04 homeassistant.components.automation: Executing RULE 2 Living Room Light OFF at 23:00pm
16-04-21 11:55:04 homeassistant.core: Bus:Handling <Event logbook_entry[L]: domain=automation, message=has been triggered, name=RULE 2 Living Room Light OFF at 23:00pm>
16-04-21 11:55:04 homeassistant.core: Bus:Handling <Event call_service[L]: service=turn_off, domain=switch, service_call_id=1979121168-7, service_data=entity_id=['switch.lampu_ruang_tamu']>
16-04-21 11:55:04 homeassistant.components.switch.command_switch: Running command: sudo /var/opt/homeassistant/rfoutlet/RF1OFF.sh
16-04-21 11:55:04 homeassistant.core: Bus:Handling <Event service_executed[L]: service_call_id=1979121168-7>
16-04-21 11:55:05 homeassistant.components.automation: Executing RULE 2 Living Room Light OFF at 23:00pm
16-04-21 11:55:05 homeassistant.core: Bus:Handling <Event logbook_entry[L]: domain=automation, message=has been triggered, name=RULE 2 Living Room Light OFF at 23:00pm>
16-04-21 11:55:05 homeassistant.core: Bus:Handling <Event call_service[L]: service=turn_off, domain=switch, service_call_id=1979121168-8, service_data=entity_id=['switch.lampu_ruang_tamu']>
16-04-21 11:55:05 homeassistant.components.switch.command_switch: Running command: sudo /var/opt/homeassistant/rfoutlet/RF1OFF.sh
16-04-21 11:55:05 homeassistant.core: Bus:Handling <Event service_executed[L]: service_call_id=1979121168-8>
16-04-21 11:55:06 homeassistant.components.automation: Executing RULE 2 Living Room Light OFF at 23:00pm
16-04-21 11:55:06 homeassistant.core: Bus:Handling <Event logbook_entry[L]: domain=automation, message=has been triggered, name=RULE 2 Living Room Light OFF at 23:00pm>
16-04-21 11:55:06 homeassistant.core: Bus:Handling <Event call_service[L]: service=turn_off, domain=switch, service_call_id=1979121168-9, service_data=entity_id=['switch.lampu_ruang_tamu']>
16-04-21 11:55:06 homeassistant.components.switch.command_switch: Running command: sudo /var/opt/homeassistant/rfoutlet/RF1OFF.sh
16-04-21 11:55:06 homeassistant.core: Bus:Handling <Event service_executed[L]: service_call_id=1979121168-9>
16-04-21 11:55:07 homeassistant.components.automation: Executing RULE 2 Living Room Light OFF at 23:00pm
16-04-21 11:55:07 homeassistant.core: Bus:Handling <Event logbook_entry[L]: domain=automation, message=has been triggered, name=RULE 2 Living Room Light OFF at 23:00pm>
16-04-21 11:55:07 homeassistant.core: Bus:Handling <Event call_service[L]: service=turn_off, domain=switch, service_call_id=1979121168-10, service_data=entity_id=['switch.lampu_ruang_tamu']>
16-04-21 11:55:07 homeassistant.components.switch.command_switch: Running command: sudo /var/opt/homeassistant/rfoutlet/RF1OFF.sh
16-04-21 11:55:07 homeassistant.core: Bus:Handling <Event service_executed[L]: service_call_id=1979121168-10>
16-04-21 11:55:08 homeassistant.components.automation: Executing RULE 2 Living Room Light OFF at 23:00pm
16-04-21 11:55:08 homeassistant.core: Bus:Handling <Event logbook_entry[L]: domain=automation, message=has been triggered, name=RULE 2 Living Room Light OFF at 23:00pm>
16-04-21 11:55:08 homeassistant.core: Bus:Handling <Event call_service[L]: service=turn_off, domain=switch, service_call_id=1979121168-11, service_data=entity_id=['switch.lampu_ruang_tamu']>
16-04-21 11:55:08 homeassistant.components.switch.command_switch: Running command: sudo /var/opt/homeassistant/rfoutlet/RF1OFF.sh
16-04-21 11:55:08 homeassistant.core: Bus:Handling <Event service_executed[L]: service_call_id=1979121168-11>
16-04-21 11:55:09 homeassistant.components.automation: Executing RULE 2 Living Room Light OFF at 23:00pm
16-04-21 11:55:09 homeassistant.core: Bus:Handling <Event logbook_entry[L]: domain=automation, message=has been triggered, name=RULE 2 Living Room Light OFF at 23:00pm>
16-04-21 11:55:09 homeassistant.core: Bus:Handling <Event call_service[L]: service=turn_off, domain=switch, service_call_id=1979121168-12, service_data=entity_id=['switch.lampu_ruang_tamu']>
16-04-21 11:55:09 homeassistant.components.switch.command_switch: Running command: sudo /var/opt/homeassistant/rfoutlet/RF1OFF.sh
16-04-21 11:55:09 homeassistant.core: Bus:Handling <Event service_executed[L]: service_call_id=1979121168-12>
16-04-21 11:55:10 homeassistant.components.automation: Executing RULE 2 Living Room Light OFF at 23:00pm
16-04-21 11:55:10 homeassistant.core: Bus:Handling <Event logbook_entry[L]: domain=automation, message=has been triggered, name=RULE 2 Living Room Light OFF at 23:00pm>
16-04-21 11:55:10 homeassistant.core: Bus:Handling <Event call_service[L]: service=turn_off, domain=switch, service_call_id=1979121168-13, service_data=entity_id=['switch.lampu_ruang_tamu']>
16-04-21 11:55:10 homeassistant.components.switch.command_switch: Running command: sudo /var/opt/homeassistant/rfoutlet/RF1OFF.sh
16-04-21 11:55:10 homeassistant.core: Bus:Handling <Event service_executed[L]: service_call_id=1979121168-13>
16-04-21 11:55:11 homeassistant.components.automation: Executing RULE 2 Living Room Light OFF at 23:00pm
I’m puzzled and unsure why this happens, any pointers anyone?
Thanks and appreciate the help.
Looks like it is triggering every second, could it be as simple as adding “Seconds: 00” to your trigger platform?
hey @photo64 that seems to do the trick. i would never figure it out for sure. i thought seconds are optional and hence i didnt even bother putting it in.
thanks heaps
