chris4
(christian )
October 20, 2020, 11:00pm
1
HI I’m trying to secure a switch to turn on the lights for flowers that are inside the garage in the winter.
For example: when the sun rises, after 1 hour the switch should trigger and turn on the light, for 8 hours, then should turn off
Have tried sun integration but have not succeeded. What is it that is wrong.
- alias: 'Automatic flowers with Sun'
- platform: numeric_state
entity_id: sun.sun
value_template: "{{ state_attr('sun.sun', 'elevation') }}"
above: 1.00
- platform: state
entity_id: switch.telldus_tzwp_102_plug_in_switch_switch_4
to: 'on'
for: '08:00:00'
choose:
sequence:
service: switch.turn_off
nickrout
(Nick Rout)
October 21, 2020, 1:41am
2
This should be an action, not a trigger.
That is not “sun is up for an hour” it is “sun above horizon by 1 degree”
arretx
(Jon Griffith)
October 21, 2020, 5:58am
3
You have two triggers to your action that are in an “either/or” setup. If one or the other happens, the switch is turned off.
You want a trigger that fires the action, and that trigger could be any state or attribute of the sun.sun platform.
Then, your action would be to turn on the light, delay for 8 hours, then turn off the light.
chris4
(christian )
October 21, 2020, 9:02am
4
Should I change to is better now?
I’m a little confused, could you help me?
Thank you.
- alias: 'Automation Flower with Sun'
- event: sunrise
platform: sun
offset: '00:60:00'
- service: switch.turn_on
- event: sunrise
platform: sun
offset: '07:00:00'
- service: switch.turn_off
Joerg
October 21, 2020, 2:39pm
5
If you want to stay with the elevation, try this
- alias: Light on for 8 hours
description: ''
entity_id: sun.sun
above: '1'
value_template: '{{ state.attributes.elevation }}'
condition: []
data: {}
entity_id: switch.officedesk
- delay: 08:00:00
data: {}
mode: single
You have one trigger: the sun elevation.
There is no condition and there are two (three actions), one action for turning on, followed by a delay of 8 hours and an action to turn the switch off after that delay time.
chris4
(christian )
October 21, 2020, 4:36pm
6
Thanks, I’ll try this tomorrow when the sunrise is up
chris4
(christian )
October 22, 2020, 4:07pm
7
It works with your automation.
Thanks again
