Hi!
I’m trying to think through how to setup an automation that will automatically change the thermostat target cooling temperature based on the outdoor temperature. I want my target temperature to be equal to 20 degrees cooler than the outdoor temperature if it’s above 95F degrees outside (95F or below, I’d like it set at a static 75F degrees target). I have a sensor to grab the outdoor temperature, but I’m not sure how to implement the automation with it? Any help/suggestions or ideas are welcome!
Thanks!
-Chad
My thermostat automation:
# Main Floor Thermostat Automation
- alias: "Set Main Floor Thermostat Cool Target"
initial_state: True
hide_entity: true
platform: state
entity_id: input_slider.main_thermostat_cool_target
service: mqtt.publish
data_template:
topic: "smartthings/Main Floor Thermostat/coolingSetpoint"
retain: true
payload: '{{ states.input_slider.main_thermostat_cool_target.state }}'
My sensors in thermostat.yaml:
- platform: mqtt
name: "Main Floor Thermostat State"
state_topic: "smartthings/Main Floor Thermostat/thermostatOperatingState"
retain: true
- platform: mqtt
name: "Main Floor Thermostat Heat Target"
state_topic: "smartthings/Main Floor Thermostat/heatingSetpoint"
unit_of_measurement: '°F'
retain: true
- platform: mqtt
name: "Main Floor Thermostat Cool Target"
state_topic: "smartthings/Main Floor Thermostat/coolingSetpoint"
retain: true
- platform: mqtt
name: "Main Floor Thermostat Mode"
state_topic: "smartthings/Main Floor Thermostat/thermostatMode"
retain: true
- platform: mqtt
name: "Main Floor Thermostat Humidity"
state_topic: "smartthings/Main Floor Thermostat/humidity"
retain: true
