Is there a way to run automation to check the configuration?
The service call you are looking for is:
homeassistant.check_config
If you go to Developer Tools > Services, you can scroll through all the available services in the Service field:
Thanks @123
I’m trying to do something like this:
new version, automation fires and checks for errors using the example above.
if there are no errors, trigger the update.
2.a) once update is done, send a success push notification -
if check fails, send a failure push notification
I think I can make most of it, but the step to trigger an automation depending on the config check result is missing. Can this be done? I could not find any state or event from the config Check script.
Any suggestions?
There is none. In general, service calls work like subroutines, not functions, because they return nothing.
Here is my automation for config check and proceed with HA backup and restart on condition config check has no errors.
#template sensors
invalid_config_check:
value_template: >-
{%- if states.persistent_notification.invalid_config.state == 'notifying' -%}
invalid
{%- else -%}
valid
{%- endif -%}
config_check:
value_template: >-
{%- if states.persistent_notification.homeassistant_check_config.state == 'notifying' -%}
invalid
{%- else -%}
valid
{%- endif -%}
#Automation:
- id: '123'
alias: Home restart
description: Restart HA on condition Config is valid
- platform: time
at: 03:00:00
condition:
- condition: time
weekday:
- sun
- service: homeassistant.check_config
- delay: 00:00:40
- alias: Restart on condition
choose:
- alias: validate and restart
conditions:
- condition: state
entity_id: sensor.config_check
state: valid
- condition: state
entity_id: sensor.invalid_config_check
state: valid
sequence:
- service: hassio.addon_stdin
addon: 15d21743_samba_backup
input: trigger
- delay: 00:05:00
- service: notify.mobile_phone
title: HA Restart Notification
message: Configuration is valid, HA is going to restart.
ttl: 0
priority: high
- delay: 00:00:05
- service: homeassistant.restart
default:
message: Home Assistant not restarted, invalid configuration identified. {{state_attr('persistent_notification.invalid_config',
'message')}} {{state_attr('persistent_notification.homeassistant_check_config',
'message')}}
ttl: 0
priority: high
mode: single
That’s an interesting workaround for the service call not returning a value. It relies on checking the status of the persistent notification that (may have been) produced by the service call.
What are you using to clear the persistent notification’s ‘notifying’ status? Are you manually reading/deleting the notification to clear it?
Thanks!
I changed the template to this in the hope it is correct. I never worked with templates before:
template:
- sensor:
- name: invalid_config_check
state: >-
invalid
{%- else -%}
valid
{%- endif -%}
- sensor:
- name: config_check
state: >-
invalid
{%- else -%}
valid
{%- endif -%}
I suggest creating a single Template Binary Sensor. It will be on
if there’s either persistent_notification present (otherwise, off
template:
- binary_sensor:
state: >-
{{ states.persistent_notification.invalid_config.state == 'notifying'
or states.persistent_notification.homeassistant_check_config.state == 'notifying' }}
I’m trying to understand how the persistent_notification works… do I need to manually create states.persistent_notification.invalid_config
or is this being created automatically by the config_check plugin? I’m using the official Check Home Assistant configuration
Home Assistant Add-on, but I never see any persistent notification created by it.
I feel its more safer to clear the errors manually than using automation (hope there is one available) so I can troubleshoot and fix them before automation triggers for config check again.
This is how it should be in your config.yaml file
that’s a great suggestion.
Make an invalid entry in config file and save the file, then run the config check or run service call - ha-config_check - this will generate persistent_notification entity which you can see in developer tools - states.
