Appox
November 8, 2018, 11:46pm
1
Hey there,
I’m new to HA and try to configure an Ikea Tradfri wireless dimmer to control one ceiling light.
Since my Json and Yaml skills are none existent, I’m failing miserably.
Could someone have a look why nothing happens? The script gets triggered, but the brightness doesn’t change.
Thanks in advance!
- id: '1541714862043'
alias: Tradfri Dimmer
- entity_id: sensor.0x000b57fffe2ccfd8
platform: state
service: light.turn_on
entity_id: light.flur_unten
data_template:
entity_id: >
{% if is_state('sensor.0x000b57fffe2ccfd8', '0') %}
{"state":"OFF"}
{% else %}
{"state":"ON","brightness": {{ states("sensor.0x000b57fffe2ccfd8") | int }} }
{% endif %}`
I think what you’re looking for is:
- alias: Tradfri Dimmer off
platform: state
condition:
condition: template
value_template: "{{ trigger.to_state.state|int == 0 }}"
service: light.turn_off
- alias: Tradfri Dimmer on
platform: state
condition:
condition: template
value_template: "{{ trigger.to_state.state|int != 0 }}"
data_template:
brightness: "{{ trigger.to_state.state|int }}"
Appox
November 9, 2018, 1:00am
3
Thank you so much, that worked great!
Sorry to jump on this thread, but does this mean that hassio can use the tradfri remotes to control any device?
I was under the impression that they didn’t really have any control. As in, they communicated directly with the tradfri bulb??
I don’t have a sensor from the ikea tradfri in my HA, but I do see that events are triggered when the dimmer is rotating. What now?
MickL
(Mick)
June 29, 2019, 9:13am
6
When you connect the dimmer/remote with the bulp they communicate directly. When you connect both to your zigbee gateway they are both available in Home Assistant. Therefor you can do what ever you want with your dimmer or remote.
I recommend installing node-red to hassio because home assistant automation gets complicated quickly.
huuub
(Jeroen Houben)
November 17, 2020, 9:19am
7
I control my Sonos with it to be able to put it on/off, volume control and rotate to (in this case) 3 radio stations, the tradfri. is connectes by a deconz conbee 2:
short press 1 : if radio is off, turn on if already playing volume + 5%
long press 1 : change radio station
short press 1 : volume down 5%
long press 1 : pause playing
- id: '1605543313862'
alias: Operate sonos Single 1 by remote
description: ''
- platform: event
event_type: deconz_event
event_data:
condition: []
- choose:
- conditions:
- condition: not
conditions:
- condition: state
entity_id: media_player.sonos_single1
state: playing
- condition: template
value_template: '{{ trigger.event.data.event == 1002 }}'
sequence:
- service: media_player.media_play
data: {}
- conditions:
- condition: state
state: playing
sequence:
- service: media_player.volume_set
data_template:
volume_level: '{{ states.media_player.sonos_single1.attributes.volume_level
+ 0.05 | float }}'
- conditions:
- condition: state
state: playing
value_template: '{{ trigger.event.data.event == 2002 }}'
sequence:
data_template:
- 0.05 | float }}'
- conditions:
- condition: state
state: playing
value_template: '{{ trigger.event.data.event == 2001 }}'
sequence:
- service: media_player.media_pause
data: {}
- conditions:
- condition: state
state: playing
value_template: '{{ trigger.event.data.event == 1001 }}'
sequence:
- entity_id: media_player.sonos_single1
service: media_player.select_source
data_template:
source: >-
{% set curSource = state_attr('media_player.sonos_single1','source') %}
{% if curSource == 'VRT Studio Brussel' %}
Willy Radio
{% elif curSource == 'Willy Radio' %}
VRT Radio 2 Limburg
{% else %}
VRT Studio Brussel
{% endif %}
default: []
mode: queued
max: 10
