Hello everyone,
I’m still fairly new to the Home Assistant or ESP Home world. Nevertheless, I am currently desperately trying to set up an irrigation system for my plants. Admittedly, I’ve stuck to existing projects for the time being in order to get to grips with Home Assistant and learn how it works and the code structure.
This is designed so that I can use an input/select field in Home Assistant to select a predefined time period (18:15, 18:30, …) at which the system starts watering the respective zone.
Now I have the problem that the automation doesn’t work, but I don’t get any error codes either, so I think it could be because I’m probably comparing two different types. In the log the time is displayed as “has_time has sent ‘XX:XX’ ”. However, nothing happens at the time I set.
Does anyone have an idea or suggestion to nudge me in the right direction. My solution is probably very cumbersome anyway. Any help would be greatly appreciated!
These are the code snippets i am trying to compare:
1.
time:
- platform: homeassistant
timezone: Europe/Amsterdam
text_sensor:
lambda: |-
char float[6];
time_t currTime = id(hass_time).now().timestamp;
strftime(float, sizeof(float), "%H:%M", localtime(&currTime));
return { float };
update_interval: 10s
and the code that should activate the automation:
2.
# Time automations
interval:
- interval: 1sec
then:
- lambda: |-
if (!id(automation_enabled).state) return;
int current_day = id(hass_time).now().timestamp / 86400;
if ((current_day - id(var_skip_start_day)) % ((int)id(skip_days).state + 1) != 0) return;
if (id(zone1_enabled).state &&
!id(irrigation_zone1).state &&
id(id(has_time).state) == id(zone1_start).state)
id(irrigation_zone1).turn_on();
