Automation for temperature warning
I am moving away from OpenHab in favor of HomeAssistant and while migrating most of the automations was fairly easy, I am stuck with my temperature warning.
I have a group with all my temperatures in my house and I want to trigger an notification if one of those temperatures falls under a curtain value. So far not a problem - but I want to display in the notification which temperature (in which room) it is that drops below.
And I want to notify only once - not on every temperature change. Only if the temperature goes over a threshold I will reset the warning state and it should notify again.
This is my Rule / Automation in OpenHab.
This should help:
