Typical Garage door light turn on/off automation, Does my logic look right. I want to turn on the light as soon as I open the door, then I want to keep the light on if the door is open OR if the door is closed and there is motion. Most the time I walk out to the garage, grab something ,and then go back in to the house. But if I’m working in the garage with the door closed, I want the lights to stay on. I’m still learning, but… I think this should work? Am I missing anything or is there a better way to do this.
binary_sensor.centralite_3320l_0cceb5d4_1_1280 is open close
binary_sensor.centralite_3305s_02f13445_1_1280 is motion
- alias: Turn on Garage Light and then off with no motion and door closed
- platform: state
entity_id: binary_sensor.centralite_3320l_0cceb5d4_1_1280
to: 'on'
- platform: state
entity_id: binary_sensor.centralite_3305s_02f13445_1_1280
to: 'on'
- service: switch.turn_on
entity_id: switch.switch_4
- condition:
condition: and
conditions:
- condition: state
to: 'off'
for:
minutes: 2
- condition: state
to: 'off'
- service: switch.turn_off
I would make two seperate automations… one for the turning on… and one for the turning off and have the condition of motion detected For the off automation
I have a similar situation, but my problem is a little unique. I have two automations. I open my basement door and the basement lights turn on. No problem. When no motion is detected for 10 minutes, turn off the lights. Also no problem.
My problem is the lights turning off when there was never any motion to begin with. It’s common for us to open the basement door to grab something at the top of the stairs, then close the door. The lights turn on but the automation to turn off the lights is set to trigger when the motion is a 0 for 10 minutes. This won’t actually trigger until someone goes down there.
This is what I use now, You should be able to tweak it for your needs. Basically If I open the garage and close it and no motion was detected the lights turn off right away. You may need to adjust the times based on how far your motion sensor is from your open close sensor
- alias: 'Motion Lighting Garage turn light on'
- platform: state
entity_id: binary_sensor.open_close_sensor_garage_door
to: 'on'
- platform: state
entity_id: binary_sensor.motion_sensor_garage_motion
to: 'on'
entity_id: switch.garage_light_indoor
- alias: 'Motion Lighting Garage turn light off'
- platform: state
to: 'off'
for:
minutes: 1
- platform: state
to: 'off'
for:
seconds: 5
condition:
- condition: state
state: 'off'
for:
minutes: 1
Yup, this is what worked for me. Just needed your sample code to wrap my head around how this needed to work and I’m good to go. The key for me was having multiple automations. One automation to turn the lights off after 10 minutes of no motion. Then another automation to turn the lights off when the basement door shuts IF there hasn’t been any motion in the last minute.
edit: I lied. Apparently I had a couple cocktails and didn’t remember how I did this. Here’s the code below that worked for me:
alias: Garage - Turn off lights
- entity_id: sensor.basement_multisensor_burglar
for: 00:10
platform: state
to: '0'
- entity_id: binary_sensor.basement_door_sensor
platform: state
to: 'off'
condition: []
- delay: 00:01
- condition: state
state: '0'
for: 00:01
- data:
entity_id: switch.workbench_lights
service: homeassistant.turn_off
- data:
entity_id: switch.garage_lights
So the automation is triggered if no motion is detected for 10 (+1) minutes. OR… if the basement door is closed, the automation will wait 1 minute and if no motion detected kill the lights.
