Automation: gas-electric hybrid heating schedule
Hi All, I am trying to set up an automation that would control my heating in a hybrid manner (gas + electric vs electric only)
This is what I have so far - the morning selector works fine, however when the gas boiler is engaged, the quota trigger does not seem to work properly. What am I doing wrong? Should I change the mode to Parallel perhaps?
Automation code
alias: "Heating: Daily schedule"
description: >-
  Gas-electric hybrid schedule for the entire day
  Checks the outside temperature at 6:30 every morning and depending on the
  measurement, it triggers either full electric heating or Gas-electric hybrid
  schedule. When Gas heating is engaged, it should switch to full electric after consuming 3.5 m3 (daily quota)
  - platform: time
    at: "06:30:00"
  - platform: state
    entity_id:
      - sensor.daily_gas_consumption
    to: "3.5"
    id: Gas quota reached
    enabled: true
  - platform: time
    at: "19:00:00"
condition: []
  - choose:
      - conditions:
          - condition: trigger
            id:
              - Morning
        sequence:
          - alias: >-
              Turn on Gas heating if outside temp is below 3 Celsius, else
              switch on A/C
            if:
              - condition: numeric_state
                entity_id: sensor.home_temperature
                below: 3
            then:
              - service: climate.set_temperature
                  temperature: 22.5
                  entity_id:
                    - climate.gaz_futes
                enabled: true
            else:
                  entity_id:
                    - climate.nappali_ac
                    - climate.nobo_heater
                  hvac_mode: heat
                  temperature: 22.5
      - conditions:
          - condition: and
            conditions:
                id:
                  - Gas quota reached
                enabled: true
              - condition: time
                weekday:
                  - mon
                  - tue
                  - wed
                  - thu
                  - fri
                  - sat
                  - sun
                before: "10:00:00"
        sequence:
          - service: climate.set_hvac_mode
              hvac_mode: heat
              entity_id: climate.nappali_ac
              temperature: 10
              entity_id: climate.gaz_futes
              temperature: 22.5
              entity_id: climate.nobo_heater
      - conditions:
            id:
              - Evening
        sequence:
              temperature: 17
mode: single
