Good Evening All,
I hope someone could help!
Sorry if this is a silly/stupid question HA is new to me as is .yaml!!!
I have just retro-fitted a eWeLink 4 relay wifi output board to my coffee machine to make it smart (smarter than me)
Output 1 - Power/Warm up
Output 2 - Flat Coffee
Output 3 - Latte
I have added the eWeLink integration to my HA and can control the outputs via that. However i would like to setup a couple of automations based on the 3 outputs above.
I would like to carry out the following:
Automation 1:
If O/P 1 is triggered from HA it only keeps it toggles it for say 00:05:00 minutes then turns it back off again.
Automation 2:
If i select the Flat Coffe (output 2) it latches output 1 on for 00:01:45 minutes and after minute 1 it latches output 2 for 45 seconds (enough time for it to make the coffee) and then turns off both outputs.
Automation 3:
Same as Automation 2 but with the Latte output 3. I can adjust the timers to suit this after.
I hope this makes sense
