Setup Hass and working well but I just can’t get my head around automation which in this case I have been trying to setup via the GUI.
I have an electric wallheater which doesn’t regulate the temperature itself too well so.
Would like for the Zwave 6 in 1 device which is measuring temp to turn on/off heater only after it has been manually turned on and never after turned off.
Any help appreciated. When I manually execute automations they follow the temperature rules but they never get invoked automatically, especially the heater off when the condition of temperate above is set.
For automations, think of triggers as defining when the actions should run, and the conditions defining if the actions should run when one of the triggers “fires.”
