I was somewhat surprised that I couldn’t find a specific example to follow. I’m relatively new to HA and this is my first automatons with multiple triggers and multiple conditions.
Essentially what I’m attempting is Disable Nabu Casa cloud connection if both phones are home and enable if either phone leaves. I’m not using the iphone integration for presence tho. The binary sensors used in the automation DO work… On= Home, Off= away.
Essentially the logic boils down to:
- if phone_1 = off OR phone_2 = off then enable cloud.
- if phone_1 = on AND phone_2 = on then disable cloud
The first case is relatively straight forward, the second case I fought with for way too long, convinced it needed to be split in two for awhile, but I think I’ve got it correct below: if someone could just confirm… suggestions welcome as well. (to be honest, due to weather conditions today and tomorrow this is hard to test, other wise I’d just test by leaving and returning until I was sure it was correct.)
Thanks!
alias: enable cloud connections
description: ''
- type: turned_off
platform: device
device_id: <redacted string 1>
entity_id: binary_sensor.<redacted 1>_iphone
domain: binary_sensor
- type: turned_off
platform: device
device_id: <redacted string 2>
entity_id: binary_sensor.<redacted 2>_iphone
condition: []
- service: cloud.remote_connect
data: {}
mode: single
alias: Disable cloud Connection
description: ''
- type: turned_on
platform: device
- type: turned_on
platform: device
condition:
- type: is_on
condition: device
- type: is_on
condition: device
- service: cloud.remote_disconnect
data: {}
mode: queued
max: 10
