I have put my solar heating system temperature monitoring into HA and I have created an Automation that triggers if the temperature in the pool is greater than or equal to the water coming in from the roof for 30 mins. (no point in pumping in same temp or cooler water)
The only thing is this will be always triggering as the temperature values change, will that cause problems with resources of HA if this is always running? Is there a better way to handle this sort of automation?
alias: Pool Heater - Temperature Comparison
description: >-
Checks temps of pool and solar return and turns off if Pool is over return
temperature, after 1 hour will rerun heater.
- platform: state
entity_id:
- sensor.shelly_pool_temperature
- sensor.shelly_roof_return_temperature
condition:
- condition: time
before: "18:00:00"
after: "10:00:00"
- condition: template
value_template: >-
{{ states('sensor.shelly_pool_temperature') | float >
states('sensor.shelly_roof_return_temperature') | float }}
- delay:
hours: 0
minutes: 15
seconds: 0
milliseconds: 0
- if:
value_template: >-
then:
- service: switch.turn_off
data: {}
entity_id: switch.spareplug
- delay:
hours: 1
minutes: 0
seconds: 0
milliseconds: 0
- if:
- condition: time
before: "18:00:00"
weekday:
- sun
- mon
- tue
- wed
- thu
- fri
- sat
after: "00:00:00"
then:
- service: switch.turn_on
data: {}
mode: single
