im trying to do an automation that welcomes me, or whoever i add, home when our presence is changed from away to home but it doesn’t seem to ever trigger. im using one that just detects when my phone connects to the wifi. i know its detecting me as a card on my lovelace updates when i connect and disconnect from the wifi. but the automation never triggers. Any ideas?
alias: Announce blanks arrival
description: ''
- platform: state
entity_id: device_tracker.blank
to: home
for:
hours: 0
minutes: 0
seconds: 0
milliseconds: 0
condition: []
- service: notify.alexa_media_blanks_s_echo_dot
message: 'blank has Arrived '
mode: single
I think device_trackers change from “not_home” to “home” (“away” is an invalid state), you also do not need the “for” so this could be simplified as follows:
description: ''
- platform: state
to: home
condition: []
mode: single
Another way to achieve this would be to create a person entity that references one (or more) device_trackers then use the person changing to home in the trigger rather than the device_tracker. This is particularly useful is you have more than one device_tracker that can be associated with a person.
As Jonah said, the state isn’t away it’s not_home, as mentioned in the docs.
Any time you’re working with states, the current actual state can be seen in Developer Tools → States. Anything you see elsewhere, or in entity history, is translated and so can’t be trusted.
