I would need some advice on how to configure an automation to feed a 3kW heating rod with 3phases (1kW) each connected to a Shelly Pro 1PM Switch when solar overproduction occurs and shouldn’t be sold/feeded into the grid.
I want Shelly1 enabled when 1kW+ occurs, second Shelly enabled when another 1kW (so 2kW in total) occurs and the third Shelly when another 1kW (so 3kW in total) occurs.
I am bit struggling with this kind of setup as 1st Shelly is obvious but 2nd and 3rd I can’t figure out on how to deal with it.
Also of course all Shellys should be disabled when no more solar overproduction occurs and the sensor reports less than 100W overproduction.
Any recommendations or workflow on how to get this done?
Here is one example I started off but the 2nd Shelly is of course enabled when 2000kW+ (so 3000kW+ in total) is reported which doesn’t make sense.
I have disabled the turning off sequence as of now but struggle a bit with the full setup:
alias: Heizstabsteuerung bei PV Überschuss description: von 1100W bis 3100W in 3 Stufen schaltbar trigger: - platform: numeric_state entity_id: - sensor.strom_zuruck_ins_netz id: PV Überschuss - unter 100W below: 100 - platform: numeric_state entity_id: - sensor.strom_zuruck_ins_netz above: 1100 below: 2100 id: PV Überschuss - 1100W bis 2100W - platform: numeric_state entity_id: - sensor.export_power above: 2100 below: 3100 id: PV Überschuss - 2100W bis 3100W - platform: numeric_state entity_id: - sensor.strom_zuruck_ins_netz above: 3100 id: PV Überschuss - über 3100W condition: [] action: - choose: - conditions: - condition: trigger id: - PV Überschuss - unter 100W sequence: - service: switch.turn_off data: {} target: entity_id: - switch.heizstab_1 - switch.heizstab_2 - switch.heizstab_3 alias: Stäbe 1,2 und 3 AUS (unter 10W) - conditions: - condition: trigger id: - PV Überschuss - 1100W bis 2100W sequence: - service: switch.turn_on data: {} target: entity_id: switch.heizstab_1 enabled: true - service: switch.turn_off data: {} target: entity_id: - switch.heizstab_2 - switch.heizstab_3 enabled: false alias: Stab 1 AN / Stäbe 2 und 3 AUS (1100W) - conditions: - condition: trigger id: - PV Überschuss - 2100W bis 3100W sequence: - service: switch.turn_on data: {} target: entity_id: - switch.heizstab_1 - switch.heizstab_2 - service: switch.turn_off data: {} target: entity_id: switch.heizstab_3 enabled: false alias: Stäbe 1 und 2 AN / Stab 3 AUS (2100W) - conditions: - condition: trigger id: - PV Überschuss - über 3100W sequence: - service: switch.turn_on data: {} target: entity_id: - switch.heizstab_1 - switch.heizstab_2 - switch.heizstab_3 alias: Stäbe 1,2 und 3 AN (3100W) mode: restart trace: stored_traces: 10000
