Hi there I am trying to get an automation so that when music is being played on Kodi it will automatically switch on my LED TV backlights. I should point out that the LED backlights do not have discrete power on/off commands. This means that I can’t just blast the off command every time Kodi goes from music to idle otherwise the lights will just turn on and off all over the place.
I thought I had an idea by adding a condition to check that the input boolean (which is the TV backlight switch of sorts) if it is on then allow for the off process to happen. But not having luck.
Lights come on just fine but not off.
- id: '1551012847304'
alias: TV backlight on when playing music
platform: template
value_template: "{% if is_state_attr('media_player.kodi', 'media_content_type', 'music' ) %}true{% endif %}"
condition: []
service: input_boolean.turn_on
entity_id: input_boolean.tv_backlight
- id: '9402512847736'
alias: TV backlight off after playing music
platform: state
entity_id: media_player.kodi
to: 'idle'
condition:
condition: state
state: 'on'
service: input_boolean.turn_off
Really appreciate any thoughts on this.
