Automation help light switch
have been weeks that I can not find the right configuration my idea is as follows: turn on the lights after sunset keep them on until 11pm and then turn on by PIR until 04:00 am.
this is the current configuration, which at this moment the lights come on regularly after sunset but remain on without the other automations intervening. is anyone so kind to help me?
- alias: 'Luci strada sera accese'
      platform: sun
      event: sunset
      offset: "-00:30:00"
  condition:
    condition: and
    conditions:
      - condition: time
        before: '22:59:59'
    - service: homeassistant.turn_on
      entity_id: "switch.luci_giardino"
- alias: 'Luci strada notte'
      platform: state
      entity_id: binary_sensor.motion
      to: 'on'
  condition:
    condition: and
    conditions:
      - condition: time
        after: '23:00:00'
        before: '03:00:00'
    - delay:
        seconds: 120
    - service: homeassistant.turn_off
your spacing is REALLY HARD to see what you have done. Use the code function.
I use a delay in one of my automations that is like this:
  - delay: '01:00:00'
That’s a 1hr delay but 120 seconds would be 00:02:00
sorry, I have now formatted my post well.
  • delay:
    seconds: 120
this delay is two minutes that the lights stay on after they detect a movement
ok you’re spacing is all over the place - 2 spaces not 4… but that might not be the issue…
Why are you using an and condition when you don’t have 2 conditions? I’m removing your and condition because it’s pointless and may be causing problems for you.
Also, you don’t really need the condition for turning on because 30 minutes after sunset should always be before 11 pm. Unless you live at the top of Sweden or something. I’ll leave the condition in, but if you live in an area where the sunset is always before 11 pm, then you don’t need the condition in the 'Luci strada sera accese' automation.
Next, you need to turn them off in order to turn them on by PIR. So at 11 pm, they need to shut off, otherwise they will stay on until PIR is triggered, so in theory, they could stay on all night if nothing moves.
lastly, you have all your entity_id’s in quotes. You don’t need to do that. I don’t think it hurts or helps your config, either way, I removed the quotes.
    - platform: sun
      event: sunset
      offset: "-00:30:00"
  condition:
    - condition: time
      before: '22:59:59'
      entity_id: switch.luci_giardino
- alias: 'turn off lights at 11pm'
    - platform: time
      at: '23:00:00'
    - platform: state
      to: 'on'
  condition:
    - condition: time
      after: '23:00:00'
      before: '04:00:00'
    - delay:
        seconds: 120
it works, really thank you very much for dedicating your time and expertise to me. I thought about putting two conditions because I believed that the first condition was the sunset the second condition the time. I will study the logic that you used for future projects thanks again.
