Hello all…
Could someone help out for an automation
On a (shelly) or any (button) switch?
For now I made 2 automations
With tts.google_translate_say
The first says: Fountain is on
Second say: Fountain is off
Question is …
Can this be made in just 1 Automation?
And pls provide example?
Thnx!
If you post the 2 automations you want to combine then I am sure someone will provide what you need.
Ok Rossk…ty!
Let’s try this then
Script 1
alias: Fontein aan
description: ""
- platform: device
type: turned_on
device_id: 149b9d6cdea56582735880d7a8a58aa4
entity_id: ec85af3e05f8d66feda97c449146533e
domain: light
condition: []
- service: tts.google_translate_say
cache: false
entity_id: media_player.nestmini2308
message: "De Fontein is nu aangezet "
language: nl
mode: single
Then the second one to turn it off
alias: Fontein uit
description: ""
- platform: device
type: turned_off
domain: light
condition: []
cache: false
message: "De Fontein is nu uitgezet "
language: nl
mode: single
I hoped this could be merged
Or changed in just 1 Automation…
Thnx…
You can use trigger IDs to know what triggered your automation.
description: ""
mode: single
- platform: state
entity_id:
- light.ec85af3e05f8d66feda97c449146533e
to: "on"
- platform: state
entity_id:
to: "off"
condition: []
- choose:
- conditions:
- condition: trigger
id:
- Turned on
sequence:
language: nl
message: De Fontein is nu aangezet
entity_id: media_player.office_echo_dot
cache: false
- conditions:
id:
- Turned off
sequence:
language: nl
message: De Fontein is nu uitgezet
cache: false
Thank You mekaneck!!!
This worked fine…
Your help is appreciated!
Good that you got help!
Please take the time to mark the answer as solution, you do that by selecting the three dots under the post:
Then select the check box:
This can be useful to other users as well and prevents that someone else steps in to try to help you.
if i could find that buton i would, but it’s not shown anywhere!
only got share … flag… edit…bookmark…delete…post admin actions…
Now I have!!!
Wonder why this never showed up…
Thank you people!!
Shorter version using templates:
- platform: state
entity_id: light.ec85af3e05f8d66feda97c449146533e
- "off"
- "on"
to:
- "on"
- "off"
language: nl
message: De Fontein is nu {{ "aan" if trigger.to_state.state == "on" else "uit"}}gezet
cache: false
If the light is reliably on
or off
and not unavailable
or unknown
, you can remove the to:
and from:
sections also.
Also thnx to Troon!
Short as possible and effective…
Kuddo’s
