I have an accupancy input select that incl. vacation. When I select vacation it triggers and automation:
- platform: state
entity_id: input_select.Occupancy
state: 'Vacation'
All actions that follow are logically executed when this state change to vacation happens.
However what I also want is that as long as occupancy input select is ‘vacation’ (so not only when the state changed) evaluate the setpoint of the thermostat and if this is above value x set it back to e.g. 12 degrees.
Would the easiest way be to build a trigger that checks “if temp above” with condition “input select on vacation” ? Or are there smarter ways to do this?
