Netatmo works fine - sensor data is displayed in groups in default view. Log from console:
16-10-08 15:07:52 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_off>
16-10-08 15:07:52 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_on>
16-10-08 15:07:52 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=homeassistant, service=toggle>
16-10-08 15:07:52 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=homeassistant, service=reload_core_config>
16-10-08 15:07:53 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=persistent_notification, service=create>
16-10-08 15:07:53 INFO (Thread-1) [homeassistant.bootstrap] Home Assistant core initialized
16-10-08 15:07:53 INFO (Thread-1) [homeassistant.loader] Loaded history from homeassistant.components.history
16-10-08 15:07:53 INFO (Thread-1) [homeassistant.loader] Loaded recorder from homeassistant.components.recorder
16-10-08 15:07:53 INFO (Thread-1) [homeassistant.loader] Loaded http from homeassistant.components.http
16-10-08 15:07:53 INFO (Thread-1) [homeassistant.loader] Loaded discovery from homeassistant.components.discovery
16-10-08 15:07:53 INFO (Thread-1) [homeassistant.loader] Loaded group from homeassistant.components.group
16-10-08 15:07:53 INFO (Thread-1) [homeassistant.loader] Loaded updater from homeassistant.components.updater
16-10-08 15:07:53 INFO (Thread-1) [homeassistant.loader] Loaded logbook from homeassistant.components.logbook
16-10-08 15:07:53 INFO (Thread-1) [homeassistant.loader] Loaded frontend from homeassistant.components.frontend
16-10-08 15:07:53 INFO (Thread-1) [homeassistant.loader] Loaded api from homeassistant.components.api
16-10-08 15:07:53 INFO (Thread-1) [homeassistant.loader] Loaded automation from homeassistant.components.automation
16-10-08 15:07:53 INFO (Thread-1) [homeassistant.loader] Loaded conversation from homeassistant.components.conversation
16-10-08 15:07:53 INFO (Thread-1) [homeassistant.loader] Loaded netatmo from homeassistant.components.netatmo
16-10-08 15:07:53 INFO (Thread-1) [homeassistant.loader] Loaded sensor from homeassistant.components.sensor
16-10-08 15:07:53 INFO (Thread-1) [homeassistant.loader] Loaded switch from homeassistant.components.switch
16-10-08 15:07:53 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=recorder>
16-10-08 15:07:53 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=http>
16-10-08 15:07:53 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=history>
16-10-08 15:07:53 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=discovery>
16-10-08 15:07:53 INFO (Thread-1) [urllib3.connectionpool] Starting new HTTPS connection (1): pypi.python.org
16-10-08 15:07:54 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=updater>
16-10-08 15:07:54 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=api>
16-10-08 15:07:54 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=frontend>
16-10-08 15:07:54 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=logbook, service=log>
16-10-08 15:07:54 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=logbook>
16-10-08 15:07:54 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=conversation, service=process>
16-10-08 15:07:54 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=conversation>
16-10-08 15:07:55 INFO (ThreadPool Worker 0) [homeassistant.loader] Loaded camera from homeassistant.components.camera
16-10-08 15:07:55 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=netatmo>
16-10-08 15:07:55 INFO (Thread-1) [homeassistant.loader] Loaded sensor.netatmo from homeassistant.components.sensor.netatmo
16-10-08 15:08:10 ERROR (Thread-1) [homeassistant.components.sensor.netatmo] Module name: "Pole" not found
16-10-08 15:08:10 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=None, entity_id=sensor.netatmo_sypialnia_temperature, new_state=<state sensor.netatmo_sypialnia_temperature=20.4; friendly_name=Temp., icon=mdi:thermometer, unit_of_measurement=°C @ 2016-10-08T15:08:10.990283+02:00>>
16-10-08 15:08:10 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=None, entity_id=sensor.netatmo_sypialnia_humidity, new_state=<state sensor.netatmo_sypialnia_humidity=53; friendly_name=Wilgotność, icon=mdi:water-percent, unit_of_measurement=% @ 2016-10-08T15:08:10.994690+02:00>>
16-10-08 15:08:10 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=None, entity_id=sensor.netatmo_sypialnia_co2, new_state=<state sensor.netatmo_sypialnia_co2=1293; friendly_name=CO2, icon=mdi:cloud, unit_of_measurement=ppm @ 2016-10-08T15:08:10.999227+02:00>>
16-10-08 15:08:11 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=None, entity_id=sensor.netatmo_sypialnia_battery, new_state=<state sensor.netatmo_sypialnia_battery=Full; friendly_name=Bateria, icon=mdi:battery @ 2016-10-08T15:08:11.003795+02:00>>
16-10-08 15:08:11 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=None, entity_id=sensor.netatmo_parter_temperature, new_state=<state sensor.netatmo_parter_temperature=23.1; friendly_name=Temp., icon=mdi:thermometer, unit_of_measurement=°C @ 2016-10-08T15:08:11.008226+02:00>>
16-10-08 15:08:11 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=None, entity_id=sensor.netatmo_parter_humidity, new_state=<state sensor.netatmo_parter_humidity=53; friendly_name=Wilgotność, icon=mdi:water-percent, unit_of_measurement=% @ 2016-10-08T15:08:11.012563+02:00>>
16-10-08 15:08:11 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=None, entity_id=sensor.netatmo_parter_noise, new_state=<state sensor.netatmo_parter_noise=45; friendly_name=Hałas, icon=mdi:volume-high, unit_of_measurement=dB @ 2016-10-08T15:08:11.017214+02:00>>
16-10-08 15:08:11 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=None, entity_id=sensor.netatmo_parter_pressure, new_state=<state sensor.netatmo_parter_pressure=1017.9; friendly_name=Ciśnienie, icon=mdi:gauge, unit_of_measurement=mbar @ 2016-10-08T15:08:11.021651+02:00>>
16-10-08 15:08:11 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=None, entity_id=sensor.netatmo_parter_co2, new_state=<state sensor.netatmo_parter_co2=1099; friendly_name=CO2, icon=mdi:cloud, unit_of_measurement=ppm @ 2016-10-08T15:08:11.026495+02:00>>
16-10-08 15:08:11 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=sensor>
16-10-08 15:08:11 INFO (MainThread) [homeassistant.core] Bus:Handling <Event platform_discovered[L]: platform=netatmo, service=load_platform.sensor, discovered=>
16-10-08 15:08:11 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=camera>
16-10-08 15:08:11 INFO (MainThread) [homeassistant.core] Bus:Handling <Event platform_discovered[L]: platform=netatmo, service=load_platform.camera, discovered=>
16-10-08 15:08:11 INFO (ThreadPool Worker 3) [homeassistant.loader] Loaded camera.netatmo from homeassistant.components.camera.netatmo
16-10-08 15:08:11 INFO (Thread-1) [homeassistant.loader] Loaded switch.rpi_gpio from homeassistant.components.switch.rpi_gpio
16-10-08 15:08:11 INFO (Thread-1) [homeassistant.loader] Loaded rpi_gpio from homeassistant.components.rpi_gpio
16-10-08 15:08:11 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=rpi_gpio>
16-10-08 15:08:11 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=None, entity_id=switch.glazienka, new_state=<state switch.glazienka=off; friendly_name=Łazienka, icon=mdi:fire @ 2016-10-08T15:08:11.093549+02:00>>
16-10-08 15:08:11 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=None, entity_id=switch.gwoda, new_state=<state switch.gwoda=off; friendly_name=Bojler, icon=mdi:water @ 2016-10-08T15:08:11.098236+02:00>>
16-10-08 15:08:11 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=None, entity_id=switch.gkuchnia, new_state=<state switch.gkuchnia=off; friendly_name=Kuchnia, icon=mdi:fire @ 2016-10-08T15:08:11.102079+02:00>>
16-10-08 15:08:11 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=None, entity_id=switch.gsalon, new_state=<state switch.gsalon=off; friendly_name=Salon, icon=mdi:fire @ 2016-10-08T15:08:11.105750+02:00>>
16-10-08 15:08:11 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=None, entity_id=group.all_switches, new_state=<state group.all_switches=unknown; entity_id=[], auto=True, hidden=True, friendly_name=all switches, order=0 @ 2016-10-08T15:08:11.110609+02:00>>
16-10-08 15:08:11 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=<state group.all_switches=unknown; entity_id=[], auto=True, hidden=True, friendly_name=all switches, order=0 @ 2016-10-08T15:08:11.110609+02:00>, entity_id=group.all_switches, new_state=None>
16-10-08 15:08:11 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=None, entity_id=group.all_switches, new_state=<state group.all_switches=off; entity_id=('switch.glazienka', 'switch.gwoda', 'switch.gsalon', 'switch.gkuchnia'), auto=True, hidden=True, friendly_name=all switches, order=0 @ 2016-10-08T15:08:11.117510+02:00>>
16-10-08 15:08:11 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=switch, service=turn_off>
16-10-08 15:08:11 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=switch, service=turn_on>
16-10-08 15:08:11 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=switch, service=toggle>
16-10-08 15:08:11 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=switch>
16-10-08 15:08:11 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=None, entity_id=group.default_view, new_state=<state group.default_view=unknown; entity_id=('group.parter', 'group.poddasze', 'group.pole', 'group.grzejniki', 'sensor.sensor_time'), hidden=True, friendly_name=default_view, view=True, order=1 @ 2016-10-08T15:08:11.214729+02:00>>
16-10-08 15:08:11 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=None, entity_id=group.parter, new_state=<state group.parter=unknown; entity_id=('sensor.netatmo_parter_co2', 'sensor.netatmo_parter_humidity', 'sensor.netatmo_parter_noise', 'sensor.netatmo_parter_pressure', 'sensor.netatmo_parter_temperature'), friendly_name=Parter, order=2 @ 2016-10-08T15:08:11.219728+02:00>>
16-10-08 15:08:11 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=None, entity_id=group.pole, new_state=<state group.pole=unknown; entity_id=('sensor.netatmo_pole_battery', 'sensor.netatmo_pole_humidity', 'sensor.netatmo_pole_max_temp', 'sensor.netatmo_pole_min_temp', 'sensor.netatmo_pole_temperature'), friendly_name=Pole, order=3 @ 2016-10-08T15:08:11.224655+02:00>>
16-10-08 15:08:11 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=None, entity_id=group.poddasze, new_state=<state group.poddasze=unknown; entity_id=('sensor.netatmo_sypialnia_battery', 'sensor.netatmo_sypialnia_co2', 'sensor.netatmo_sypialnia_humidity', 'sensor.netatmo_sypialnia_temperature'), friendly_name=Góra, order=4 @ 2016-10-08T15:08:11.229646+02:00>>
16-10-08 15:08:11 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=None, entity_id=group.grzejniki, new_state=<state group.grzejniki=off; entity_id=('switch.glazienka', 'switch.gkuchnia', 'switch.gsalon', 'switch.gwoda'), friendly_name=Grzejniki, order=5 @ 2016-10-08T15:08:11.234827+02:00>>
16-10-08 15:08:11 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=<state group.default_view=unknown; entity_id=('group.parter', 'group.poddasze', 'group.pole', 'group.grzejniki', 'sensor.sensor_time'), hidden=True, friendly_name=default_view, view=True, order=1 @ 2016-10-08T15:08:11.214729+02:00>, entity_id=group.default_view, new_state=<state group.default_view=off; entity_id=('group.parter', 'group.poddasze', 'group.pole', 'group.grzejniki', 'sensor.sensor_time'), hidden=True, friendly_name=default_view, view=True, order=1 @ 2016-10-08T15:08:11.238029+02:00>>
16-10-08 15:08:11 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=group, service=reload>
16-10-08 15:08:11 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=group>
16-10-08 15:08:11 INFO (Thread-1) [homeassistant.loader] Loaded automation.time from homeassistant.components.automation.time
16-10-08 15:08:11 INFO (Thread-1) [homeassistant.components.automation] Initialized rule Turn on heater in living room
16-10-08 15:08:11 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=None, entity_id=automation.turn_on_heater_in_living_room, new_state=<state automation.turn_on_heater_in_living_room=on; last_triggered=None, friendly_name=Turn on heater in living room @ 2016-10-08T15:08:11.431346+02:00>>
16-10-08 15:08:11 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=automation, service=trigger>
16-10-08 15:08:11 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=automation, service=reload>
16-10-08 15:08:11 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=automation, service=turn_on>
16-10-08 15:08:11 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=automation, service=turn_off>
16-10-08 15:08:11 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=automation, service=toggle>
16-10-08 15:08:11 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=automation>
16-10-08 15:08:11 INFO (MainThread) [homeassistant.core] Starting Home Assistant (11 threads)
16-10-08 15:08:11 INFO (MainThread) [homeassistant.core] Starting Home Assistant core loop
16-10-08 15:08:11 INFO (MainThread) [homeassistant.core] Bus:Handling <Event homeassistant_start[L]>
16-10-08 15:08:11 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=homeassistant, service=stop>
16-10-08 15:08:11 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=homeassistant, service=restart>
16-10-08 15:08:11 INFO (MainThread) [homeassistant.core] Timer:starting
16-10-08 15:08:11 INFO (Thread-4) [netdisco.service] Scanning
16-10-08 15:08:15 INFO (CP Server Thread-5) [homeassistant.components.http] Serving /api/stream to 192.168.1.108 (auth: True)
16-10-08 15:08:15 INFO (CP Server Thread-6) [homeassistant.components.http] Serving /api/bootstrap to 192.168.1.108 (auth: True)
16-10-08 15:08:16 ERROR (ThreadPool Worker 3) [homeassistant.components.camera] Error while setting up platform netatmo
File "/usr/local/lib/python3.4/dist-packages/homeassistant/helpers/entity_component.py", line 107, in _setup_platform
discovery_info)
File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/camera/netatmo.py", line 45, in setup_platform
for camera_name in data.get_camera_names():
File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/camera/netatmo.py", line 103, in get_camera_names
self.update()
File "/usr/local/lib/python3.4/dist-packages/homeassistant/util/__init__.py", line 296, in wrapper
result = method(*args, **kwargs)
File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/camera/netatmo.py", line 117, in update
self.welcomedata = lnetatmo.WelcomeData(self.auth)
File "/home/pi/.homeassistant/deps/lnetatmo.py", line 291, in __init__
if not self.homes : raise NoDevice("No camera available")
lnetatmo.NoDevice: No camera available
16-10-08 15:08:32 INFO (Thread-4) [urllib3.connectionpool] Starting new HTTP connection (1): 192.168.1.108
