Hello, relatively new to HA and having a little “logic” problem with one of my automations…
I have a fan in the bedroom in front of a window with a open/close & temp sensor.
I want the fan to turn on when the window is open, the house “mode” is night, and the temperature of the window is above a certain temp (i.e., when it is hot and the window is open and it is nighttime, turn on the fan to help cool the bedroom). This automation seems to be working.
The issue is with the second automation used to turn off the fan. It is kind of the mirror of the turn on: turn off the fan if the window is closed, if the house “mode” is daytime, or if the temp at the window is below a certain temp. I can’t seem to get that last piece to work.
Here’s the YAML for the automation:
alias: Turn Oscillating Fan Off Based on Temperature
description: ''
- type: temperature
platform: device
device_id: e198441a20e4aa9376ed1b231afdf27b
entity_id: sensor.mb_sensor_pauls_window_temperature
domain: sensor
above: 0
for:
hours: 0
minutes: 5
seconds: 0
milliseconds: 0
below: 73
- type: turned_off
platform: device
entity_id: binary_sensor.mb_sensor_pauls_window_ias_zone
domain: binary_sensor
- platform: state
entity_id: input_select.house_mode
to: Day
condition:
- condition: device
type: is_on
device_id: b6d84c53a6407ec7b0682f347127e381
entity_id: switch.mb_plug_fan_on_off
domain: switch
- type: turn_off
domain: switch
mode: single
When the temperature at the window is below 73 degrees for more than 5 minutes (according to HA), it does not turn off the fan. It does turn off when the house_mode becomes Day, and I think (not 100% sure) that it turns off if I close the window, just not when the temp goes below a certain threshold.
I feel like I must be missing something basic. Any ideas what I’m doing wrong?
This only triggers the automation if it starts above the threshold e.g 75 then go below the threshold e.g 70 and stays for more than 5 minutes below the threshold.
It will not trigger the automation if since the beginning its already under 73.
So for the “turn off”, the temperature when mode becomes (not) “day” (sunset) is usually well above the 73 degree threshold and then some time during the night goes below the threshold of 73, so that seems like it shouldn’t be the problem, but since I have three “triggers”, could that be a problem where one or more should be “conditions”?
The way I was thinking, is:
If the temperature goes below 73 degrees for 5 minutes (a trigger), the automation will be executed (assuming the fan is “on” (condition) and regardless of whether the window is open or the time of day).
If I close the window (a trigger), the automation will be executed (again, assuming the fan is “on” and regardless of temp and time of day)
If the mode becomes “day” (dawn), the automation will be executed (again, assuming the fan is “on” and regardless of temperature and whether the window is open).
Does that work or am I missing something (I’m assuming any one trigger being “true” executes the automation, not all three)?
So now I’m wondering if my thinking about triggers vs conditions in these instances is incorrect. Or if I should simplify and create several different automations, each with a single trigger (for turning off as listed above).
OR - I suggest using state trigger rather than device_id - in case you need to replace the device, you just need to change the new entity_id to sensor.mb_sensor_pauls_window_temperature.
… is that it the state at the beginning must be evaluated as FALSE, then changed and evaluated as TRUE - for the automation to be triggered. The only exception of this is if the trigger calculates numeric_value instead of boolean_value.
In your case, the temperature needs to be above your threshold (e.g 75) - which is evaluated as FALSE, then go below your threshold (e.g 70 for more than 5 minutes) - which evaluates as TRUE.
To make your automation more compact, you can use-
description: ''
mode: single
- platform: numeric_state
below: '73'
above: '0'
for: '00:05:00'
- platform: state
to: 'off'
- platform: state
to: 'Day' ## VERIFY the actual state of `input_select.house_mode` from Developer Tools
condition:
- condition: state
state: 'on'
- service: switch.turn_off
