I have a automation created in the front end that i feel should work but it doesn’t and wondering if anyone can assist.
I live in a RV/caravan so my location changes all the time as i travel the country. My RVWiFi router " used to " report the geo location of my switches using NMAP. but since a recent router firmware update there is no space left on the router to reinstall extra packages.
So… plan b was to create a automation that detected when i drive away from the caravan ( using the switch.ute_power entity). If its unavailable then i’m not near the caravan. But when i return and switch.ute_power shows “off” then i must be near the caravan, so use my phones lat and longitude data to update the lat and long attributes of the router and the caravans location and set.location.
However, the below automation sends me the Telegram message saying its been updated but when i look in the states tab both person.caravan and the RVWiiFi device tracker and set.location still have incorrect coordinates. Any suggestions please ?
oh and if i copy the value templates into the templates tab it returns correct details so assuming they are actually correct.
alias: Update Location
- entity_id: switch.ute_power
for: '15'
platform: state
to: 'off'
condition:
- condition: and
conditions:
- condition: template
value_template: 'value_template: "{{ ( states.person.larry.attributes.latitude )
!= ( states.person.caravan.attributes.latitude ) }}"'
- data:
latitude: '{{ states.person.larry.attributes.latitude }}'
longitude: '{{ states.person.larry.attributes.longitude }}'
data_template:
latitude: '{{ states.device_tracker.rvwifi_lan.attributes.latitude }}'
longitude: '{{ states.device_tracker.rvwifi_lan.attributes.longitude }}'
service: homeassistant.set_location
- data:
message: The Caravans location has just been updated
service: notify.larrys_phone
- data:
entity_id: person.caravan, device_tracker.rvwifi_lan
service: homeassistant.update_entity
Happy to not focus on the Router getting updated as im not concerned about that. But back a few months ago when i had it working using nmap the reasoning was … If “person.caravan” changes location then set.location to person.caravans new coordinates
cheers
