Automation help with sunset condition
Can anyone tell me where I’m going wrong?
I have 2 floodlights that don’t have PIR(yet) attached to my garage, so I set my back door to turn on these lights when opened. Now I want to make sure this is only done when dark, around sunset.
  • alias: Turn on Garage Light
    platform: state
    entity_id: binary_sensor.door_window_sensor_158d0000fd1d75
    to: ‘on’
    condition:
    condition: sun
    event: sunset
    offset: “-00:15:00”
    service: homeassistant.turn_on
    entity_id: script.garage_light
I’m getting this error, but unsure what to do next.
extra keys not allowed @ data[‘condition’][0][‘conditions’][0][‘event’]. Got None
Try this. I believe event is a one time action. If you want the light to come on any time after the sun sets you want to use below_horizon.
- alias: "Turn on Garage Light"
    - platform: state
      to: 'on'
  condition: state
      entity_id: sun.sun
      state: 'below_horizon'
## Motion sensor frontdoor
- alias: Light on
    - platform: state
      entity_id: sensor.visitor
      to: '1'
  condition:
    - condition: sun
      after: sunset
      # Optional offset value
      after_offset: "0:30:00"
    - service: homeassistant.turn_on
      entity_id: switch.light.frontdoor
- alias: Light off after 5 minuts
    - platform: state
      to: '0'
      for:
        minutes: 5
        seconds: 30
    - service_template: homeassistant.turn_off
This is what I use.
Ahh, with both of your help, I came up with this, which works great. Thank you!
- alias: Turn on Garage Light
    platform: state
    to: 'on'
  condition:
    condition: state
    entity_id: sun.sun
    entity_id: script.garage_door
Hi All,
I am using the following automation however am getting an error. Herewith the config which is in automation.yaml
  • alias: “Main Bedroom is Cold”
    • platform: numeric_state
      entity_id: sensor.master_bedroom_motion_sensor_temperature
      below: 20
      condition: state
      entity_id: sun.sun
      state: ‘below_horizon’
      entity_id:
    • switch.master_anna_heater
  • alias: “Main Bedroom is Hot”
      above: 23
      condition: state
      entity_id: sun.sun
      service: homeassistant.turn_off
      entity_id:
However this is the error I am getting in the logs with HA not able to start
File “uvloop/loop.pyx”, line 1879, in uvloop.loop.Loop.call_exception_handler (uvloop/loop.c:35028)
stdout
14:44:07
File “/usr/src/app/homeassistant/core.py”, line 95, in async_loop_exception_handler
stdout
14:44:07
_LOGGER.error(“Error doing job: %s”, context[‘message’], **kwargs)
stdout
14:44:07
KeyError: 'message’e[0m
stdout
14:44:08
e[31m17-03-09 14:44:08 ERROR (Dummy-15) [homeassistant.core] Error doing job: Task was destroyed but it is pending!e[0m
stdout
14:44:08
stdout
14:44:12
Config directory: /config
stdout
14:44:14
e[31m17-03-09 14:44:14 ERROR (Thread-3) [homeassistant.util.yaml] mapping values are not allowed here
stdout
14:44:14
in “/config/automation.yaml”, line 651, column 16e[0m
stdout
14:48:11
stdout
14:48:12
e[31m17-03-09 14:48:12 ERROR (Thread-3) [homeassistant.util.yaml] mapping values are not allowed here
stdout
14:48:12
Any ideas on where I am going wrong?
btw Line 651 is entity_id: sun.sun…
the condition you are using with “below horizon” just triggers as true if the sun is already set i guess, is there a way to set an offset ? because its quite dark in my home an hour before sunset, so this condition would not really work for me.
or is the offset just for an event?
Maybe use elevation as a condition instead of sunset??
          - condition: numeric_state
            entity_id: sun.sun
            value_template: '{{ state.attributes.elevation }}'
            below: 10
Could someone confirm this is the right way to use offsets for a sun condition. I want it to be true from 30 min before sunset to 30min after sunrise:
    - condition: or
      conditions:
        - condition: sun
          after: sunset
          after_offset: "-00:30:00"
        - condition: sun
          before: sunrise
          before_offset: "+00:30:00"
Based on your statement:
This would be correct.
    - condition: or
      conditions:
        - condition: sun
          after: sunrise
          after_offset: "+00:30:00"
        - condition: sun
          before: sunset
          before_offset: "-00:30:00"
I need the condition to be true at night and add 30min before and after it.
What I meant is:
from sunset -30min
to sunrise +30min
I think your condition is true for daylight?
So my condition above is correct right?
Yep, you’re right. You just phrased it oddly in your original post.
Yes, I did sorry :smiley: Saw that after you posted your condition.
