I think it’s just because the condition specifies after 2:30am, and before 10:30pm. That means it only evaluates to true in the day time, the exact opposite of what you want. Try this:
condition:
- condition: or
conditions:
- condition: time
before: '02:30:00'
- condition: time
after: '22:30:00'
- condition: time
weekday:
- mon
- tue
- wed
- thu
- fri
- sat
- sun
If the condition applies for every day of the week, it seems unnecessary to use the weekday: option and list all seven days.
The documentation for Time Condition indicates it can span across midnight. Therefore this should be valid (and very similar to the documentation’s example):
condition:
condition: time
after: '22:30:00'
before: '02:30:00'
Did you try your original version but with the 00:45:00 delimited by single-quotes?
- id: 'master_bedroom_lights_off'
alias: Master Bedroom Lights Off
entity_id: group.all_master_bedroom
platform: state
to: 'on'
for: '00:45:00'
condition:
condition: time
after: '22:30:00'
before: '02:30:00'
- service: homeassistant.turn_off
I just experimented with the automation and discovered something interesting.
I set the time period to be from 20:30 to 21:30.
I set the duration (for:) to 10 minutes.
I turned the light on at 20:28.
The light failed to turn off at 20:38.
At 20:40 I manually turned the light off and then back on.
The light turned off at 20:50.
At 21:00 I turned the light on.
At 21:10 the light turned off.
At 21:25 I turned the light on.
It did not turn off at 21:35 (i.e. past the boundary of the time period).
It would appear that the automation expects to see a state-change from off to on during the time period before it begins counting the duration. If the light is already on before the time period begins, it won’t start counting the duration.
In light of this result, this automation, in its current form, is unlikely to work the way you want.
If group.all_master_bedroom is already on before 22:30 then this automation will never turn it off.
If group.all_master_bedroom is turned on at 02:00 it will not be turned off 45 minutes later, at 02:45, because that’s beyond the time period’s boundary (02:30).
I believe one solution might be to move the condition section into the action section. It doesn’t fix the second issue only the first one. However, it may do it a bit too aggressively. If the group is already on for 45+ minutes before 22:30, it will get immediately turned off at 22:30.
platform: state
to: 'on'
for: '00:45:00'
- condition:
condition: time
after: '22:30:00'
before: '02:30:00'
No if you go to dev tools and click on <> and type in the group name it will show the state of the group… when it is on and off… I’m just confirming you have the right state in your automation.
oh i see what you mean, yeah I went to the states tab and looked for my automation. It says on. I toggled it on and off… I’m running out of ideas might just pick back tomorrow
