Hi, i start with hass.io a few days ago.
I integrate zwave and homematic components via cc3.
Now i want to use the Homematic hardware button to switch the light connected to zwave.
I can switch the zwave light from gui.
So i look into log to get the id from homematic button:
2019-12-24 14:14:16 INFO (Thread-2) [pyhomematic.devicetypes.generic] HMGeneric.event: address=000193C99D4A69:1, interface_id=homeassistant-HMIP, key=PRESS_SHORT, value=True
i write down to configuration.yaml
automation test:
platform: event
event_type: homematic.keypress
event_data:
channel: 1
param: PRESS_SHORT
service: switch.turn_on
entity_id: switch.qubino_goap_zmnhbdx_flush_2_relays_switch
i confused about the configuration files. is it possible to write the config into configuration.yaml or should i write it to automations.yaml
