Automation - Homematic PS Switches not available for automation
Hi all,
is this a bug ?
why are they not available as Device which can be switched on by automation?
Details of the switches which cannot be used in automations:
PS Switches
Automation: the first device is an AVM DECT switch which is found and can be chosen. Both others are not found by name and not by ID. If try to trick it via YAML it even is not be used/allowed/removed.
Automation
Attributes of one of the PS Switches:
interface: ip
friendly_name: Garagenlicht links
device_class: outlet
Attributes of one of the PSM Switches:
friendly_name: HomematicRPI undSwitchzuBĂĽroTerasse
so I am to stupid to use customize options in the configuration.yaml - any suggestions why all of them are ignored/not used?
#PATH-TO-HA/configuration.yaml
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
 homeassistant:
      #time_zone: Europe/Berlin
      media_dirs:
        media: /media/
      #recording: /mnt/recordings
      customize:
      # Add an entry for each entity that you want to overwrite.
        sensor.tasmota_energy_supply:
          unit_of_measurement: kWh
          state_class: total_increasing
          device_class: energy
        switch.00021be99e397d
          interface: ip
          device_class: ""
I tried to clean the attributes in this case, and the cusomizeation are all not used. Because I tried this some days ago with the tasmota device there which has also been ignored…
thanks
Marc
