Automation if a trigger happens X times in Y minutes
I have Phantom retractable screens on my patio. They are supposed to be raised if wind speed is above 25 mph. I use a Tempest weather station in my yard to monitor wind speed. My automation will raise the screens (via ESPSomfy RTS) if it sees a wind gust over 20mph. The problem with that is there are sometimes spikes in the data. I might see wind gusts around 15 mph but then 1 split second wind gust above 20mph. I can’t use a trigger duration in the automation because the gust may not last very long.
I’d like to set my automation to raise the screens if it sees 2 wind gust readings over 20mph in a 10-minute period. Is there a way to do that?
What about something like:
alias: Count Wind Gusts
description: ""
  - platform: numeric_state
    entity_id: sensor.wind_gust
    above: 20
    below: 20
    for: "00:10:00"
condition: []
  - service: counter.{{trigger.id}}
    data: {}
      entity_id: counter.wind_gust
mode: single
You could do the same kind of thing in a trigger-based template sensor as well.
template:
  - trigger:
        above: 20
        below: 20
        for: "00:10:00"
      - name: gust_counter
        state: |
          {% set current = this.state | int(0) %}
          {% if trigger.id == reset %}
            0
          {% else %}
            {{ current + 1 }}
          {% endif %}
