Hello guys,
I think I need a little bit of input. I searched a lot on google but I didn’t find anything close that could save my problem.
I think it will be easy for you, thanks for the help.
I want to trigger an automation which send me a telegram notification when the temperature outside is lower then inside.
alias: OpenWeather Temp Outside Telegram (wSensor)
description: ''
- platform: numeric_state
entity_id: sensor.openweathermap_temperature
below: -1
value_template: "{{ state.sensor.openweathermap_temperature - state.sensor.lumi_lumi_weather_temperature }}"
condition: []
- service: notify.marceltelegram
message: Temp Out 1°C lower
title: '*~~Weather~~*'
mode: single
Is this the way to go?
automation:
entity_id: sensor.outside_temperature
below: sensor.inside_temperature
It’s basically the 4th example here: https://www.home-assistant.io/docs/automation/trigger/#numeric-state-trigger
It’s basically the 4th example here: Automation Trigger - Home Assistant
This is what I already found, but I want to trigger it with a temperature delta of 1 °C between these two temps.
I did edit my first post, is this a solution?
then use a template trigger (also your template was wrong):
value_template: "{{ states('sensor.openweathermap_temperature') | int - states('sensor.lumi_lumi_weather_temperature') | int > 0 }}"
Its still not working, I changed int to float cause the values are decimal numbers
alias: OpenWeather Temp Outside Telegram (wSensor) V2
description: ''
value_template: "{{ states('sensor.lumi_lumi_weather_temperature') | float - states('sensor.openweathermap_temperature') | float > 1 }}"
condition: []
title: '*~~Weather Template V2~~*'
message: Temp 1°C lower
mode: single
You seem to have dropped the quotes around the template that finity had. You need to add those back or else make it a yaml multiline string.
You are right, ahhh these little mistakes.
Thx to all for the help
Solution by @finity
description: ''
condition: []
mode: single
finity
June 1, 2022, 11:21pm
8
While I’m not too worried about it myself (but others tend to be) it’s customary to mark the post of the person who provided you with the solution with the “solution” tag and not your own post.
Just an etiquette FYI.
123
(Taras)
June 2, 2022, 1:07am
9
FAQ guideline 21
Mark the post that identified the cause of the problem and/or suggested a corrective measure.
@finity I know but should I mark this as a solution?
I did an edit of the Solution, I hope its fine now
finity
June 2, 2022, 6:59pm
11
it honestly really doesn’t matter to me.
