Automation if washing machine is finished
With the following code i try to get an information, when the washing machine is finished.
I read the wattage from the washing machine (or rather from a power plug).
But now I have the problem, sometimes fluctuates strongly downwards even during the washing process
now to my question. Is it possible to check the wattage as a trigger but only trigger if the wattage is 2 minutes below a value?
Here is my current code
alias: Waschmaschine fertig
description: ''
    value_template: >-
      {{ states('sensor.waschmaschine_mss310_power_w_main_channel')|float <
      states('input_number.waschmaschine_fertig') | float }}
condition:
  - condition: time
    after: '06:59'
    before: '22:00'
  - service: notify.telegram_familie
      title: Waschmaschine
      message: ist fertig
  - service: script.alexa_sprachausgabe_eg_komlett
      message: Waschmaschine ist fertig
      type: announce
mode: single
yes see here
description: ''
    value_template: >-
    for: "00:02:00"
And, you can use numeric_state:
- platform: numeric_state
  entity_id: sensor.waschmaschine_mss310_power_w_main_channel
  below: input_number.waschmaschine_fertig
  for:
    minutes: 2
Thanks to both of you
I try the code from m0wlheld
It works with this code.
But I get the Info every 2:30 Minutes until I turn off the washing machine.
My code is now:
description: ''
    for:
      hours: 0
      minutes: 2
      seconds: 30
condition:
  - condition: time
    after: '06:59'
    before: '22:00'
      message: ist fertig
      type: announce
mode: single
How can I get the message only once per wash cycle
You must set the input_number reasonable low and probably extend the for time. I have a similar automation, but use a constant low threshold of 10 Watts for 10 minutes
Ok I understand, but I think this not work with my washing machine, because they have an anti-crease, so they go to higher Watts after they finished.
But thank you.
