Hi folks. I’ve scoured the forums and doc and don’t think what I want is possible but am asking y’all just to be sure.
Is it possible to provide input parameters to an automation?
For example, I have Automations A and B which trigger Automation C, setting a temperature. When I set the temperature with Automation A, I want to send a notification. When I set the temperature with Automation B, I don’t want to send a notification.
The notification is built into Automation C. Is there a way I can make Automation C accept a parameter like “sendNotification=false” that can then be used in a condition?
I understand that input helpers are a thing, but think they’re only for manipulation via the frontend, correct? If I’m overlooking something obvious, I’d appreciate any guidance. TIA!
You can use a script to do the actions and automations to call the scripts. Scripts have fields, which is a way to pass data in, like an input.
Also there is blueprints for both automations and scripts that do inputs with static values if you want to go there.
Awesome, thank you. Some light research (this post) indicates a script is essentially an automation that has to be triggered explicitly (manually or from an automation) - is that pretty much the gist of it?
Also found this post on converting an automation to a script, should be helpful.
