Hi –
Any idea why this automation is failing to run? Thank you.
Hi –
dont use comma for entities …
entity_id:
- media_player.kitchen
- media_player.library
- media_player.living_room
- media_player.office
btw paste the code rather then picture of your codes
If I click the automation it runs as I would expect but it is not executing on its own every 5 mins.
description: “Lights off after 5 min”
mode: single
Clicking “Run” only executes the automation’s action
Reference: Testing your automation
I understand that but the automation sometimes runs at 5 min intervals and other times it don’t.
The State Trigger you created will trigger when either switch’s state changes to on
and stays on
for at least 5 continuous minutes.
It doesn’t trigger the way you described:
so its not every 5 mins, but at random 5 minute intervals assuming lights are on?? Or am I misunderstanding you? On a side not Is there any script that can be used for dashboard to tell you when the next automation(s) run? I imagine not but figured to ask. Thanks for replying and tips
use that for your codes
As Taras said, the automation you written said …
You’re misunderstanding how a State Trigger works with the for
option. It’s not “at random 5 minute intervals” but the way I described above.
If the switch is off and then you turn it on, if you turn it off 4 minutes later it won’t serve to trigger the automation. It must be on for at least 5 minutes.
If the switch is off and then you turn it on, if you leave it on for at least 5 minutes it will serve to trigger the automation.
@Taras i think the confusion because it a single mode, therefore if he turn on a different light the old automation is still in affect hence turn off both light before the 5minutes of the second light? he got 2 lights as trigger
Single mode isn’t a factor.
Got it. To wrap this I think I was led to believe if on for 5 mins and the automation did not trigger as I expected. I believe its working now. As opposed to wrestling with a scene if this works consistently then that is what I am after. Now if I could only get a Rasperry Pi, home assistant is currently on a vmware vm. Freaking scalpers are loving this chip shortage to charge double prices.
If my explanation of the State Trigger’s operation helped explain its behavior, please consider marking my post above with the Solution tag. It will automatically place a check-mark next to the topic’s title which signals to other users that this topic has been resolved. This helps users find answers to similar questions.
For more information about the Solution tag, refer to guideline 21 in the FAQ.
