Automation is not getting triggered in state change
Hey all! I’m trying to trigger an automation when The state of a binary sensor changes. Its all a big mess atm. I’ve found that this works The best for one of my sensors:
alias: Motion driveway
description: ''
  - platform: state
    entity_id: binary_sensor.cam_driveway_global_motion_sensor
condition:
  - condition: state
    entity_id: input_boolean.motion_driveway
    state: 'off'
      entity_id: input_boolean.camera_driveway_trigger
  - service: timer.start
      duration: '60'
      entity_id: timer.driveway_1_min_0
      duration: '300'
      entity_id: timer.driveway_5_min_0
mode: single
It works fine with The driveway but I have The exact same setup for my doorbell and it doesnt recognize it.
I’ve tried with The state changing from off to on but that doesn’t work. If I move outside The door, The doorbell Will recognize it but it doesn’t trigger The automation. Its nothing wrong with The action since I can see when The trigger was last triggered.
How can i fix this?
Thank you
Post your actual automation that is not working.
Sorry, I have updated The post with The full automation
I found The problem. It’s an easy mistake from writing too fast. If I go into The debugging, I am able to see that it is getting triggered. There is an error though, since I have forgotten to create The actual helper…
