I’ve been pulling my hair out, watched multiple YouTube tutorials about this, and read a few threads here about this. I’m trying to do something super basic. Turn a lamp on by the door when we walk in a room. Using an Aqara P1 motion detector which works perfectly. Lamp will turn on just fine after sunset as programmed. What isn’t working is the various attempts to have a timer turn it off after 10 min of no motion. Can someone please have a look at this code and explain what I’m missing? I’ve tried using a helper timer, and then I simplified it to just use the duration option within the automations UI.
alias: 'Office: Motion Detected Lamp On'
description: ''
- type: occupied
platform: device
device_id: ea5145a700240e9e4262e9665cc2b939
entity_id: b16dc95c12ceda0889a8aca957674c87
domain: binary_sensor
- type: not_occupied
platform: device
for:
hours: 0
minutes: 10
seconds: 0
condition:
- condition: state
entity_id: sun.sun
state: below_horizon
- condition: device
type: is_off
device_id: 39a8d16b7a09864aa4b60d10a7634da7
entity_id: e59e0bea2b7f302a89b4a8f9d412fb8e
domain: light
- choose:
- conditions:
- condition: trigger
id:
- Occupied
sequence:
- action: light.turn_on
data: {}
- conditions:
id:
- Not Occupied
sequence:
- action: light.turn_off
data: {}
mode: single
123
(Taras)
August 21, 2024, 6:08pm
2
The second condition requires the light’s state to be off . That’s what is preventing the “Not Occupied” trigger from turning the light off (because the light is on).
The two triggers require different conditions:
The first trigger (motion detected) will turn the light on but only if it’s currently off.
The second trigger (no motion detected) will turn the light off but only if it’s currently on.
Here’s a simple way to do it using State Triggers , trigger variables , and a templated service call.
description: ''
- platform: state
entity_id: binary_sensor.your_motion_detector
to: 'on'
variables:
is_true: "{{ is_state('light.your_light', 'off') }}"
- platform: state
to: 'off'
for:
minutes: 10
variables:
is_true: "{{ is_state('light.your_light', 'on') }}"
condition:
- condition: state
entity_id: sun.sun
- condition: template
value_template: '{{ is_true }}'
- action: 'light.turn_{{ trigger.to_state.state }}'
entity_id: light.your_light
mode: single
Replace binary_sensor.your_motion_detector
and light.your_light
with the entity_ids of your entities.
So the above code still didn’t work quite right. After a little massaging and tinkering, I ended up with this and it’s working perfectly.
alias: "Office: Motion Detected Lamp On"
description: ""
- platform: event
event_type: timer.finished
event_data:
entity_id: timer.office_lamp_timer
- type: no_motion
platform: device
entity_id: 87520479ee0c93265a3b13905334b712
- type: motion
platform: device
condition:
- condition: state
entity_id: sun.sun
- choose:
- conditions:
id:
- Motion Stopped
sequence:
- action: timer.start
data: {}
- conditions:
id:
- Motion Detected
sequence:
- action: timer.cancel
data: {}
- type: turn_on
domain: light
- conditions:
id:
- Timer Finished
sequence:
- type: turn_off
domain: light
mode: single
