Automation light with 2 different "on" Times
Hi.
I’m currently switching my automations from NodeRed to HA Native.
I have an automation that turns on the light when a motion detector detects motion. But now I want the light to turn off after a few minutes, depending on the time of day.
E.g. between 08:00 - 20:00 the light should go out after 10 minutes and between 20:01 and 07:59 the light should go out after 5 minutes.
What is the best way to configure this in HA?
Can this be done with one automation or do I need two?
Can someone help me?
Thanks.
I would personally use one automation to set a “turn the light off” helper to either 5 or 10 minutes in the future. You would choose the 5 or 10 minutes using a choose action, and then your helper would be the trigger of the second automation which turns the lights off. While 5-10 minutes isn’t that long, it’s long enough that I would prefer not to do a wait/delay, as if you were to install updates, edit an automation, or restart home assistant during that time then the wait will never finish.
thanks for the Info.
it now works as expected.
