I am trying to create an automation and struggling a bit with the logic and how best to implement. Essentially an elaborate way to turn my robot vacuum on. I have the individual parts working but just not as one workflow. Essentially what I want to achieve is outlined below:
1 - Start trigger at 10am
2 - Condition to check its either Monday/Wednesday/Friday
3 - Verify TV is switched off (wait up to 2 hours for it to be turned off)
4 - Send notification to phone asking to turn Vacuum on
5 - Response from user will either turn on Vacuum or cancel and do nothing
6 - Turn on vacuum
Issue is I only want 4 & 5 to run if it hits the two hour time out, as is then even if the TV is off then it sends me the notification to start. I want the vacuum to start automatically if the tv is off.
Is there a way to start an automation when the timeout is hit? That way I can just move item 6 up to item 4 and create a new automation with item 4 and item 5 driven by the timeout.
I will have a play with the wait variables and see if I can get it working. It looks like I should be able to based on the link. I will report back if I succeed. (or if I don’t!)
Oh my actual days I thought I was going mad! I read through that page a number of times thought I fully understood what was going on but it still wasn’t working. A very long trial and error session behind me, it was the damned:
continue_on_timeout: false
that was still present from my previous attempt and I hadn’t spotted it! So it now works a treat!
Below is my complete automation if anyone else wants to use it as a base for something. I think I could optimise it by removing the first choose case, but now I have it working I am nervous to edit it!
