I’m trying to loop through z-wave nodes, and set a parameter (below). It seems to work, but it skips the first node and also gives the errors (below):
alias: Inovelli - 13 - LED Color Set
description: ''
- platform: sun
event: sunrise
offset: '+00:00:00'
condition: []
- repeat:
count: '{{ nodes | count }}'
sequence:
- service: zwave.set_config_parameter
node_id: '{{ nodes[repeat.index] }}'
parameter: 13
value: 0
mode: single
max: 30
variables:
nodes:
- 3
- 4
- 5
- 6
- 7
- 8
- 9
- 10
- 11
- 12
- 13
- 14
- 15
- 16
- 17
- 18
- 19
- 20
- 21
Errors:
Error while executing automation automation.inovelli_13_led_color_set: expected int for dictionary value @ data['node_id']
Inovelli - 13 - LED Color Set: Error executing script. Error rendering template for repeat at pos 1: UndefinedError: list object has no element 20
v
