Entity: Mi door sensor and schlage Lock
I would like to lock the door after Door sensor is detected to be closed for over 1 minutes.
This automation never triggered, I tried to use from on to off and also open to closed. Nothing seems to be working. This automation never triggered, I tried manually trigger it, it does lock the door.
Thanks in advance!
Code as follow
- alias: If the window is closed for 1 minutes lock the back door
platform: state
entity_id: binary_sensor.door_window_sensor_158dxxxxxab6
#from: 'on'
to: 'Closed'
for:
minutes: 1
service: lock.lock
entity_id: lock.back_door
make sure it’s off and not Off (it’s case sensitive)
It’s also a good idea to try and update your automation with dashes so each entry comes as a list.
If you want an automation to start on multiple triggers or have multiple actions, it’ll fail otherwise
- platform: state
entity_id: binary_sensor.door_window_sensor_158d0000d43ab6
to: 'off'
for:
minutes: 1
- service: lock.lock
