Dear all,
as there is still no support to reference input_number
states as above:
or below
thresholds in Numeric State triggers, I am looking for an elegant way to achieve that scenario using template triggers.
Use case:
- i have a series of motion sensors outside, which report the illuminance in lux. I use a Min/Max sensor to get the current mean value of all sensors.
sensor.illuminance_mean
- i have two Input Number helpers which receive the illuminance at sunset and sunrise,
input_number.illuminance_sunrise
andinput_number.illuminance_sunset
(using automations) - i have two Statistics sensors, which sample the last 7 value changes of those input number helpers to get the average illuminance outside at sunset and sunrise:
sensor.illuminance_sunrise
andsensor.illuminance_sunset
The overall goal is to use the values of sensor.illuminance_sunrise
and sensor.illuminance_sunset
as thresholds in an automation, which turn on/off outdoor lights if current illuminance falls below sensor.illuminance_sunset
or exceed sensor.illuminance_sunrise
This would be my automation, if using other entities in above/below:
platform: numeric_state
entity_id: sensor.illuminance_mean
above: sensor.illuminance_sunrise
below: sensor.illuminance_sunset
for: '00:05:00'
service: light.turn_{{ states('sensor.illuminance_mean') | float < states('sensor.illuminance_sunset') | float }}
entity_id: light.exterior_lights
But using other entity’s values in above/below is not supported. So I go for Template triggers like
value_template: "{{ states('sensor.illuminance_mean') | float < states('sensor.illuminance_sunset') | float }}"
for: "00:05:00"
value_template: "{{ states('sensor.illuminance_mean') | float > states('sensor.illuminance_sunrise') | float }}"
for: "00:05:00"
But does template triggers continuously trigger whenever the current illuminance is above or below threshold for more than 5 mins. How can I achieve that they only trigger once, if the monitored entity falls below or goes above the threshold initially?
