I’m looking at the RFID Tag Jukebox automation provided here and I’m seeing some things I’ve never used in my automations because I’ve mainly used NodeRED. But, I need to understand what’s going on here, so if you can help in any way, thank you.
The mode
in the automation is single and the max_exceeded
is silent. Am I to understand that the single mode prevents the automation from starting again until the entire automation has completed and that silent prevents a warning message from being generated?
If a warning is generated, is it done in the background in the log file, or is there a specific prompt in the UI?
This use case scenario seems to effectively prevent one from passing a tag over a reader multiple times, thereby causing a song to start over every time the tag is scanned. Does this sound correct?
The variables
section. It seems that we’re matching a specific reader ID with a specific media player to ensure that the music is only played on that media player if that tag reader is scanned. While I can achieve this same result through NodeRED message flows, is that the intent with this?
It also seems as though we’ve used the tags
variable to lock a tag to a specific playlist or song. Also something I think I can achieve through a switch node in NodeRED, yes?
The condition then tests the contents of the tags
variable and the media_players
variable to validate whether or not the actions should continue.
Then, in the actions, we use the variables to reference the previously stored variables…etc. I think I’m understanding, but correct me if I’m wrong.
Lastly, there’s a delay.
QUESTION:
When the jukebox is triggered, and a song begins, is there any mechanism in this automation that delays the completion of the automation prior to the end of the actual song, or are we able to re-scan the same tag after 2 seconds of delay, thereby re-triggering the same song again?
If that’s the case, I’m wondering what the purpose of the single mode with silent max is.
