Automation movement and lifx - sensor acting like toggle
Hi All,
Bit unsure of what is causing this and it seems to only be prevelant in my automation with lifx bulbs.
pretty simple… movement seen --> turn on lights --> wait 6 minutes --> turn light off.
However after movement executes the automation if you move infront of the movement sensor it toggles off the lights.
I have changed to a totaly different type of movement sensor so Im pretty sure its something in my layout.
thankyou
  alias: Guest Bathroom Lighting
  - entity_id: binary_sensor.guest_toilet_movement
    platform: state
    to: 'on'
  condition:
  - after: '17:30:00'
    before: '23:59:59'
    condition: time
  - data:
      brightness_pct: '100'
      color_name: white
      entity_id:
      - light.lifx_d0_73_d5_38_1a_e2
      - light.lifx_d0_73_d5_38_25_6e
      - light.lifx_d0_73_d5_51_c5_63
    service: light.turn_on
  - delay:
      minutes: 5
  - data:
      entity_id:
    service: light.turn_off
when an automation with a delay is triggered again during the delay it will skip all conditions and all delays/wait templates and just execute the actions. To overcome this you can create a timer and turn the lights off when the timer finishes. This way you timer will also be reset on a new motion detection. Search the forum or let me know in case you need some help.
Or just use two automations like this cookbook example:
@Burningstone ok need some help…
I have managed to get this working but I did it with
a. configuration.yaml holding the timer (im sure that is right)
b. an automation starting lights on with movement picked up by sensor
c. a second automation killing the lights after timer expires. (if I walk into the movment zone the counter starts again).
So function wise this is working fine.
Question. Is the 2 automations how this is done or am I missing something.
It’s easier to just use @tom_l suggestion.
Here the code for the same with a timer
The timer, goes into configuration.yaml
timer:
  guest_bath_light_timer:
    duration: '00:06:00'
The first automation:
Motion detected -> turn on light and start timer
When an already running timer is started it will just start again from the beginning.
- alias: "Turn on guest bathroom light on motion"
    platform: state
    to: 'on'
    - service: timer.start
      entity_id: timer.guest_bath_light_timer
    - service: light.turn_on
        color_name: white
        entity_id:
The second automation turns off the light when the timer finishes.
- alias: "Turn off lights after 6 minutes of no motion"
    platform: event
    event_type: timer.finished
    event_data:
    entity_id:
Yep thats what I ended up with… thanks guys.
