After upgrading to version HASSIO 143, messages published to mqtt from automation scripts no longer work. Well they work but the data appears to be giberish. Automation script:
alias: Washer State Washing
I believe this may be related to an open issue posted on GitHub:
The problem is reported to occur with several flavors of MQTT Broker (mosquitto, mosca, Hass.io’s built-in broker, etc) so it suggests the culprit may be Home Assistant’s MQTT component.
There’s a suggested fix (to erase all topics on the broker) but the someone has reported it did not work for them.
am facing exactly the same issue! Was using a sonoff POW which I replaced with Sonoff POWR3
Since then I am having the same issue! I am actually using the same payload for Washing and Idle.
