Automation no Trigger
after hours of trying to find a solution for my automation not triggering and reading a lot of topics, i am almost quitting. I did set up an automation via the webinterface and just, for testing, wanted to switch on my shelly if an MQTT-Topic is “1”. The Trigger isn’t working and i cant find the a solution. I checked my log but there are no triggered automations listed. I also checked under dev-tools–>states, if the automation is active.
alias: Test
description: ‘’
  • platform: state
    entity_id: switch.lichthandtuer
    to: ‘1’
    condition:
  • condition: state
    state: ‘1’
  • type: turn_on
    device_id: 6b2ff7e743720414a4e1aa6db25e5de3
    entity_id: switch.shellylichttuer
    domain: switch
    mode: single
The Problem is not that the switch-command, i have tested it by manually triggering the automation. But the Automation Trigger does not fire. :frowning:
Please Help, i have no idea, what to check. The log says switch.lichthandtuer is switched on but the automation does not trigger.
Thank You
Martin
switches can’t have a state of ‘1’. they are either ‘on’ or ‘off’.
Thanks a lot :smiley:
