I’ve set up 2 esp32 relay boards which work fine through the dashboard, I’ve set up 8 number helpers to set the upper and lower humidity levels and I’ve created an automation for each valve.
On one of the boards the relays turn on when the humidity level drops below the set point but on the other board, nothing happens, HA says the automation was triggered but the relays are not turning on.
Am I missing something?
alias: Valve 1 Humidity Control
description: ""
triggers:
- entity_id: sensor.third_reality_inc_3rsm0147z_humidity
trigger: state
conditions: []
actions:
- choose:
- conditions:
- condition: template
value_template: |
{{ states('sensor.third_reality_inc_3rsm0147z_humidity')|float
>= states('input_number.valve_1_upper_humidity')|float }}
sequence:
- target:
entity_id: switch.valve_1_2_relay
action: switch.turn_off
- conditions:
value_template: |
<= states('input_number.valve_1_lower_humidity')|float }}
sequence:
- target:
action: switch.turn_on
- action: notify.mobile_app_blobfishs_iphone_12
metadata: {}
message: valve 1 is on 2 relay
mode: single
