Hi all, here my first post. I just installed ha few days ago and I’m really enjoying it. I started to play with automations but the one I created is not fired also if conditions are met:
I wouldn’t suggest using device trigger, device condition or device actions.
They should work but sometimes they can not work.
If you want to continue this automation then use states and call services on the entities.
If you want to use something better then I would suggest setting up an generic thermostat to make your life easier to maintain.
About why it didn’t work, your trigger is empty, so nothing is triggering the automation.
You probably want both your conditions to be your triggers also.
So when you arrive home, or when temperature goes below.
