Hey guys - I am trying to create a set of automations to control my thermostats, but none of them are firing. Below is one of them as a sample. Does anyone have any ideas why this wouldnt work? The YAML passing linting and HASS does not complain at all in the logs. I’m running 0.64.3 using the official Docker image
- action:
- data:
entity_id: climate.kitchen_thermostat_224
temperature: '20'
service: climate.set_temperature
- data:
entity_id: climate.home_theater_thermos_219
temperature: '20'
- data:
entity_id: climate.basement_thermostat_209
temperature: '20'
alias: Turn on thermostats - weekends
condition:
- condition: time
weekday:
- sat
- sun
- at: '08:30:00'
platform: time
You sure the action is not triggered? Or is it just doing nothing, because they are hidden errors in the actions? For example: Do the target temperature really needs to be a string (temperature: ‘20’)
These were built with the automation editor, but the conditions for weekday added manually - so I ASSUME, the fact that they use string is fine. As for if they are triggering, nothing is showing up in the logbook for them. I will set my logs to debug and see if anything happens.
I have a similar issue, also my automations won’t work. Mystery here is that they used to work, but after some update, they no longer worked. Workday_sensor is a custom component using workalendar to find out if it’s currently a local holiday or not, and that component is working as shoulds.
Here’s contents of my automations:
- id: '15150090066001'
alias: Oikea tolppapaikka - ON
initial_state: true
- at: 09:11
platform: time
condition:
- condition: state
entity_id: binary_sensor.workday_sensor
state: 'on'
- condition: state
entity_id: binary_sensor.holiday_sensor
state: 'off'
- condition: state
entity_id: switch.right_car
state: 'off'
- data:
service: switch.turn_on
- id: '1516692766093'
alias: Oikea tolppapaikka - OFF
initial_state: true
- at: 07:40
platform: time
condition:
- condition: state
state: 'on'
- condition: state
state: 'off'
- condition: state
state: 'on'
- data:
service: switch.turn_off
- id: '1516693069695'
alias: Oikea tolppapaikka - AUTO-OFF
initial_state: true
- entity_id: switch.right_car
platform: state
to: 'on'
for:
hours: 3
condition: []
- data:
There are 3 automations which should automate vehicle heating.
Right car on: if it’s a workday and clock is 5:00 - turn switch on (turn on heating).
Right car off: same conditions as right car on, but at 7:40, turn it off.
Right car auto-off: if switch(heating) is turned on manually, or even by automation, turn it automaticly off after 3 hours.
None of these events fire or show anything in logs.
I’d look to the conditions and verify that your sensors are working properly and displaying the correct states. If those all look good, I’d check the switch and verify that it works as intended. Lastly, i’d check your system time.
All seems good now. Time is often updated from ntp servers and local time comes is derived from rtc chip, so all should be okay about time. Sensors return correct values and switch works.
Now I am testing it and I should see tomorrow if all works as intended. Maybe it was lack of initial_state…
