Automation not running when time of state is set to more than 10 min
Hi guys,
I’m having a weird issue with my AC automation, not sure why it is not running.
Automation goal: When AC 1 has been running (state = cool) for 1 hour, turn off AC 1 and start AC 2. I have another automation that will turn off AC 2 and start AC 1.
Anyway the problem is when I set the AC 1 to cool for 1 hour the automation will not trigger (Turning AC 1 OFF & AC 2 ON), but when I set it to 5 min it works perfectly.
Here is the code, appreciate your help.
If there is a better way to implement this please share.
alias: AC - Shift after 1H - Entrance Hall > OFF | Living Room > ON
description: ""
  - platform: state
    entity_id:
      - climate.ac_entrancehall
    to: cool
    for:
      hours: 1
      minutes: 0
      seconds: 0
condition: []
  - service: climate.turn_off
    data: {}
      entity_id: climate.ac_entrancehall
  - service: notify.mobile_app_fold_3m
      message: Entrance Hall AC Turned OFF
      title: "AC Update:"
  - delay:
      hours: 0
      minutes: 0
      seconds: 10
      milliseconds: 0
  - service: climate.turn_on
    data: {}
      entity_id: climate.ac_livingroom
  - service: climate.set_temperature
      temperature: 20
      hvac_mode: cool
      message: Living Room AC Turned ON
      title: "AC Update:"
mode: single
Restarting home assistant or reloading automations (including saving a new automation using the UI editor) during that one hour will prevent the trigger from happening. Did you do that?
