I have this simple automation but not working .I’m new in the home assistant world.
this is my automation :
- id: '1613218899468'
alias: turn on the light when motion detected
description: ''
- platform: device
domain: binary_sensor
entity_id: binary_sensor.couloir_chambre_sensor_on_off
device_id: 27d7baaf79a57d1addc87e04ef185f5e
type: motion
for:
hours: 0
minutes: 1
seconds: 0
milliseconds: 0
condition: []
- domain: light
entity_id: light.couloir_chambre_light_level_on_off
device_id: 85a8c8336fd25399c8e7b90a6125fad8
type: turn_on
mode: single
Do I need to restart hass every time I create an automation ?
Best regards
No, go to Configuration → Server Controls → Reload Automations.
Do you really want to wait one minute after motion has been detected to turn on the lights? Don’t you want to turn it on immediately when motion is detected? If so, remove the for:
part
I remove the for . I see that the motion sensor detect but the automation is still not trigger
![motion-detected|528x170]
When you press execute there, does it turn the light on?
Yes if I click execute the light turn on.
I don’t use UI automations, so here is the YAML version:
description: ''
platform: state
to: 'on'
service: light.turn_on
mode: single
I tried your code if I click execute the light turn on but with detection nothing happen .
I’m using home assistant core-2021.2.3. Do I need to install an addon or something like that ?
I tried the blueprint Motion-activated Light but same thing no trigering. But I’m sure my motion sensor is working![motion-detected](https://community-assets.home-assistant.io/original/3X/0/0/00e746ec09a16b51f90c7a766ac0c955c8c6e283.png)
Can you please show how the sensor looks like under Developer Tools -> States?
I found out whtat’s wrong I was using binary_sensor.couloir_chambre_sensor_on_off but hass trigger with binary_sensor.couloir_chambre_sensor_occupancy.
Now it’s working thank you for your help
