Team,
I’m quite newbie to HA so I have some doubts.
I have a tado thermostat with the controller.
I’ve installed both the original TADO integration (via cloud) as well as the Homekit integration.
I’ve read TADO has requested NOT to hammer their servers more than once every 5 minutes, while the Homekit controller should be LAN only.
My test is to power on a light when the Thermostat is in heating mode.
I’ve created 2 automations and they work fine:
This is the one via Tado Cloud
- id: '1642015836377'
alias: FanCoil Sync
description: ''
- platform: state
entity_id: sensor.piano_interrato_heating
condition: []
- choose:
- conditions:
- condition: numeric_state
above: '1'
sequence:
- service: switch.turn_on
entity_id: switch.1000f7f6ae_2
- service: notify.mobile_app_iphone_sucks
title: Fancoil Sync - On
message: T.06-2 On
default:
- service: switch.turn_off
message: T.06-2 Off
title: Fancoil Sync - Off
mode: single
This is the one via HomeKit:
- id: '1642957094557'
alias: FanCoil Sync (HomeKit)
description: ''
- platform: state
attribute: hvac_action
entity_id: climate.piano_interrato_hk
condition: []
- choose:
- conditions:
- condition: state
state: heating
sequence:
title: Fancoil Sync - On - HomeKit
message: T.06-2 On HomeKit
default:
message: T.06-2 Off HomeKit
title: Fancoil Sync - Off HomeKit
mode: single
If I run them manually is perfect the switch on and off
I’ve left the first one active and it is triggered every 20 min exactly but never in between
BUT they do not work as expected when I controll the thermostat:
When I change the temp to max → starting heating → sometimes the HK works, but often does not
When I chage the temp to off → it goes in iddle → it does not switch off the light
I’ve waited 2 minutes on each test.
Repeated the test multiple times.
What am I doing wrong?
I can understand the Tado Cloud should be updated every 5 min but why for me is every 20?
The HomeKit being lan should not be triggered in real time?
Thank you for the help
