This is one of my first automations, but it’s NOT triggered also if the config check tells me it’s ok… Can somebody tell me why doesn’t work as expected?
There’s not a play_media service call in the automation you pasted above. But you’ll need to resolve your configuration before things will work correctly.
You can get a list of valid media_player entities by using the states dev tool. It’s a button at the bottom of the left bar. Looks like <>
If that makes no difference, I’d try a simpler automation with just one trigger and one action. See if that works. If it does, add elements 1 by 1 to see when it fails.
It will be easier to help you then
You haven’t been looking very hard then , that’s standard practice.
OP
Remove the conditions, check the automation is on, check that the binary sensor is actually turning from off to on, if the automation still doesn’t fire post the error message
Thanks, I got so used to listing every action with a service and not stumbled upon such a syntax when browsing the community. You learn every day I guess
and I just noticed I did not add the service bit in my previous answer. Guess I need to stick to 1 post at a time instead of replying left, right and center
