I’m trying to set up an automation to adjust the bedroom temperature based on the selection from an input.
input_select:
kitchen_mode:
options:
- comfort
- eco
- auto
- absence
bedroom_mode:
options:
- comfort
- eco
- auto
- absence
input_number:
bedroom_temp:
name: Bedroom temperature
min: 12
max: 30
step: 0.5
automation:
alias: bedroom_automation
triggers:
platform: state
entity_id: input_select.bedroom_mode
to: "comfort"
action: climate.set_temperature
entity_id: climate.bedroom_heater
temperature: "{{ states('input_number.bedroom_temp')|float }}"
When I run the action in developer mode, it works perfectly. However, it doesn’t work within the automation. I suspect the issue comes from the triggers, but I’m not sure what the problem is.
Do you have any suggestions?
